20 Most Recent
Amana ARSE665BS Side by Side Refrigerator Questions & Answers
DOESNT DEFROST AND THE FRIDGE SIDE NOT COLD
YOU CAN MANUALLY DEFROST THIS AND GET IT GOING UNTIL YOU GET IT REPAIRED. UNPLUG REFRIGERATOR AND LEAVE FREEZER DOOR OPEN FOR 12 HOURS OR MORE. OR UNPLUG REFRIGERATOR, TAKE THE LOWER PANEL OFF INSIDE FREEZER AND DEFROST WITH A HAIR DRYER. THIS SHOULD TAKE ABOUT 45 MINUTES. THE MOST COMMON REPAIR IS THE DEFROST THERMOSTAT. YOU PROBABLY HAVE A BAD ADAPTIVE DEFROST BOARD.
Automatic ice maker doesn't fill with water
Probably the double water inlet solenoid valve on the back of the cabinet (one for the water and one for the ice, one component).
Or a blockage in the water supply line, and even on one occassion the pipe feeding the ice machine was not in situ and water runs down the back of the freezer. Easiest way to check is to locate this part (back RHS) and switch the ice and water over and see if this has an impact. If you are not a practical person do not touch the back section (compressor side). Hope this helps.
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM •
Amana...
Answered
on Jun 20, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
- Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
- Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
- Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
- Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
- Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM •
Amana...
Answered
on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM •
Amana...
Answered
on Jan 14, 2023
