20 Most Recent
Xerox Phaser 8560MFP Laser Printer Questions & Answers
07,010.43:130907
Hi Anonymous,
Please go to your Xerox concessionaire for advice.
Regards.
Unlock scan head xerox phaser 8560
The only time scan heads are locked are when they arrive from the manufacturer or the drive motor has seized up.
The former will need a 5.5mm spinner to remove the packing straps the latter will need Xerox engineer.
Good luck.
How to fix magenta background?
This sounds like a faulty Magenta Developer tank. or a ground connection on the Magenta tank. Further investigation needed.
Good Luck.
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Phaser 8560MFP/N System error
The probable situation is that 2 camshafts (020K14800 & 008K02160) have cracked, and now have taken out the Process Motor (127K53240)
Replace all 3 together, and get the "homing the process motor" and "homing the head tilt mechanism" instructions.
-Whit :)
Network printer sending message on desktop "
Check the network setups, is it set to DHCP has it been issued with a valid I.p. Address. E.g 192.168.0.123 etc?
try printing out the network setups from the printer, that might shed some light on the problem once you have all the network information at your fingertips it's much easier to make a valued decision.
Good luck.
