20 Most Recent
Mintek DTV-373-D 37 in. LCD HDTV Questions & Answers
Need Dish remote control code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
My GPX 42" Has only one code, that don't work.
Almost every cable/satellite remote control thats used beingtoday, has an "Auto Programming Feature" on the remote.Look up your model cable box online for remote codes and I almost guarantee u will find the Auto Program instructions.For Directv u hold mute+select button for about 3 secondsthe flashes and so on . . . "LOOK IT UP"
Tv is stuck in dvd mode
The on l y way I've fixed this problem is by using a universal remote control. Using the input button, you should be able to switch it back to whatever mode you need. Hopefully your television is a major manufacturer.
I need to replace the
the cost of replacing an lcd screen will be nearly as expensive as the cost of a new tv and it is also a time consuming and delicate task of removing all the pcb boards (without blowing them) to take the original screen out and then replace it all again.
Codes
If you are using a remote supplied by your cable company with their box, check their website for possible codes for your set.
TV w/ built in DVD
What a crock of **** this is guys! This FIX is surly a sad work around for the poor! Replace the mother board and solve your problem the correct way. No need to butcher up this TV. Better still, buy a name brand TV and a service contract which will save you money in the long run.
Dan Jackson - CET, which means Certified Electronics Technician
