20 Most Recent Amana ARB1905C Bottom Freezer Refrigerator Questions & Answers
I have an Amana bx21tw
Check to see if compressor is running .if not you might have a bad compressor relay
1/26/2018 7:59:34 PM • Amana ARB1905C... • Answered on Jan 26, 2018
Ice build up in the freezer
Sounds like your door seals are not seating causing moisture to migrate past the seal and condense and freeze. Check to see if this is true will small strips of paper. If you place the strip in the door and pull, you should have some resistance. If you pull and it moves freely, your door seal needs to be realigned or replaced
1/13/2018 12:19:42 AM • Amana ARB1905C... • Answered on Jan 13, 2018
We have an Amana bottom
More than likely it’s not the defrost timer it is most likely to be the bi metal it’s in the evaporator area in the freezer section
Refrigerator defrost bi-metal thermostat
Parts #: 12001937
Substitution: 12001937 I gave you the part number all you have to do is order it and install it I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
12/15/2017 7:24:20 PM • Amana ARB1905C... • Answered on Dec 15, 2017
4answers
Fridge is not cold but the light will turn on...
Try to uplug it for a few minutes then plug back in. Let us know if the compressor and fan kick on then otherwise we'll have to give more advice on where to look, etc.
12/10/2016 4:18:06 PM • Amana ARB1905C... • Answered on Dec 10, 2016
Bar fridge not cooling
Sounds like you might be low on refrigerant (gas). Unless it is 134a, which you can buy in automotive stores, you are going to need a license to buy refrigerant. The simple way to see if you might need gas is by feeling the larger line going into the compressor (probably insulated). It should be cold if your system is working and charged. If you feel the line leaving your condenser, it should be fairly warm. Be careful as the line leaving the compressor can be very hot and burn you and you may have exposed electrical. If the lines do not feel cold and warm as they should you may be low on gas or you may just have a problem with your compressor or another part of the system. If you're not getting the warm-cold differential, it's likely worth just buying a new unit.
11/12/2013 10:00:39 PM • Amana ARB1905C... • Answered on Nov 12, 2013
0answers
0answers
2answers
My Freezer isn't getting cold. It sounds like the
I suspect by your description the fridge either has a faulty overload protector or the compressor itself is seized.
If you feel like you can trouble shoot further I`ll try to assist you or you may decide to call a professional appliance technician.
**FYI, Most of the Amana fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to Whirlpool/Amana.**
Hope that help`s move you forward if nothing else. If so please take a second and rate the reply to your inquiry you received here at fixya.
Thank you and good luck.
macmarkus :)
2/20/2013 5:16:01 PM • Amana ARB1905C... • Answered on Feb 20, 2013
My fridge light is out
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/21/2011 2:37:22 AM • Amana ARB1905C... • Answered on Sep 21, 2011
I have an Amana ARB2117AW
NOTE: This
Also this might be a common Defrost problem, Ice
MORE TIPS AND TRICKS:
Leo Ponder
imufo2
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/14/2011 7:27:01 PM • Amana ARB1905C... • Answered on Aug 14, 2011
Amana ARB1905C Bottom Freezer Refrigerator Logo
95 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
bar fridge not cooling
  • Refrigerators
