20 Most Recent
Amana ARB2259CS Bottom Freezer Refrigerator Questions & Answers
The ice was full and
Hi kiverson1,
Here are common reasons for you to encounter the issue with your machine.
* Reminder: Before attempting any testing or repairs remember your safety.
1. Check the shutoff arm - An arm extends away from the ice maker over the ice cube bin. During each ice making cycle, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. As ice accumulates in the bin it prevents the arm from dropping back down. When the arm is high enough, the ice maker shuts off and no more ice is made until the ice level in the bin drops.
The ice maker can also be turned off manually by lifting the arm all the way up into a locked position.For proper operation, confirm that arm is in the lowered position and that nothing is blocking it from normal movement.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Hope it helps.
Thank you for using Fixya.
The inside water spout on this refrigerator
Checckwater pressure.The 1/4" water supply line should deliver at least 9 ounces of water in 5 seconds. If not, the water pressure is low.
Make sure the dispenser is notlocked. Some models have a lock feature that deactivates the dispenser andcontrol buttons. The lock button is located on the dispenser front cover.This feature controls unintentional dispensing. Press the"Unlock" or "Locked" button to reactivate the dispenser andallow dispenser function. You may need to hold the button for2 to 3 seconds.
A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced. Thanks.
Amana defrost
Hold the door switch closed like the door is closed for testing an
inside fan. The fan could be so quiet you might not hear it. Wet your
finger and feel for air movement. Like a Washington politician, you
might be able to feel it.
The defrost circuit showing a completed circuit means the heater and safety stat are OK I believe.
I would be more inclined to believe the board its self is at fault if
this is correct. Remove one or more of the wires going to the defrost
heater and retry it. this way you have an open circuit your sure of and
the result you get on the board means this part of the circuit logic is
operating correctly.
And the test 2
"Compressor/Condenser Fan Test" is talking about the fan motor on the
outside by the compressor not the inside fan. That is the evaporator
fan inside.
Other things that may help you:The defrost timer / or board will never be in the Freezer. Other than
that it could be in the refrigerator section behind a plastic cover or
metal cover on the back outside. It could also be under neath the front
corners or center of the front kick plate.
A timer you can turn
the cam clock wise til it clicks. A board will depend on the
manufacturer as to how to send into defrost for a test. A sensor on the
defrost type board may be required to by-pass into a defrost.
The freezer section has the only cooling coil. It sounds like it is
blocked with frost and thus wont let the air circulate from freezer to
refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost
safety thermostat. Any One of these or a combination of 2 can be your
problem. If you have a energy efficient
model that has electronic
controls then you will have a board. The procedures for checking the
circuit on a board vary by manufacturer of the board used and
manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically,
unless it is an electronic sensor type. Sensor types have a range of
resistance that needs to be known to check and varies slightly with the
temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences
that will allow you to do most of these checks. If its over your
understanding I recommend you contact a reliable technician.
If this helps you please rate me as high as you can and thank you for using fixya.l
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM •
Amana...
Answered
on Jun 20, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
- Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
- Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
- Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
- Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
- Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM •
Amana...
Answered
on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM •
Amana...
Answered
on Jan 14, 2023
