20 Most Recent Amana ARB2217C Bottom Freezer Refrigerator Questions & Answers
0answers
Not cooling
Be the first to answer 1/17/2014 12:46:07 AM • Amana ARB2217C... • Posted on Jan 17, 2014Be the first to answer
Ice in the bottom of freezer ABB224WEB
If you have an ice maker, it may be overfilling. Ice makers have a trough that dispenses the incoming water to the tray. If the ice freezes in the trough the incoming water sprays all over the freezer compartment and settles in the bottom. I fixed the same problem by thawing out the trough with a hair dryer. Then I switch the cube size from "large" to "medium" to keep it from overfilling. I have not had the same problem for years.
12/31/2013 4:18:05 PM • Amana ARB2217C... • Answered on Dec 31, 2013
0answers
Freezer compartment continually frosts up
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/31/2011 12:33:07 AM • Amana ARB2217C... • Answered on Aug 31, 2011
Water/Ice is building up in
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
If you need more help GO HERE:
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
8/22/2011 11:27:35 PM • Amana ARB2217C... • Answered on Aug 22, 2011
0answers
I have an Amana ARB2217C bottom freezer with
The problem has to be in the damper control inside the refrigerator section.
Disconnect the refrigerator from power and remove the food from the top shelf. The damper control is in the box near the top of the refrigerator section behind the temperature control knob.
Remove the knob and cover until you can access the damper control. You can prop the damper control open with a pencil or something to make the refrigerator work until you get a part if you need to. Here is the part you need.
2/19/2011 5:33:00 PM • Amana ARB2217C... • Answered on Feb 19, 2011
Amana arb2217cw how to force defrost
First, defrost the box completely. If you have access to the coils, use a hair dryer...but be careful of water/electricity as they don't mix well. If not, you'll have to turn it off and leave the doors open for at least one day to melt the ice inside. Dry what you can. Restart the box. Often, problems like this are a result of too many uncovered liquids, box set too cold, too much 'window shopping' or bad/dirty door gaskets.
1/30/2011 12:46:51 AM • Amana ARB2217C... • Answered on Jan 30, 2011
The freezer seems to be
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1/5/2011 3:21:02 AM • Amana ARB2217C... • Answered on Jan 05, 2011
0answers
I have amana
Be the first to answer 10/12/2010 12:09:21 AM • Amana ARB2217C... • Posted on Oct 12, 2010Be the first to answer
2answers
Amana refrigirator bottom freezer moderl
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
9/1/2010 1:11:33 AM • Amana ARB2217C... • Answered on Sep 01, 2010
Freezer stays cold ,but refrigerator
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigeratpor side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly to the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the advisable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Good luck.....
8/14/2010 10:48:06 PM • Amana ARB2217C... • Answered on Aug 14, 2010
Amana bottom Freezer with top refrigerator - Ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
7/13/2010 6:58:20 PM • Amana ARB2217C... • Answered on Jul 13, 2010
Freezer section gets below 0 fresh food side will
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
6/4/2010 5:33:24 AM • Amana ARB2217C... • Answered on Jun 04, 2010
Freezer not working
Good day,
Remove the back cover on the bottom and locate the compressor. See if the clicking sound is coming from it.
If so, there are usually 3 components pressed onto the pins of the body of the compressor. You have to remove the protective cover first.
The components are the protective overload disk, start relay and on some models a start/run capacitor.
You can take the components after prying them off the pins of the compressor and take them to an appliance parts house. They will usually check them for you. Replace any that check bad.
If they all test good then you will need the services of a professional to check the compressor itself.
If the noise is coming from another area, please post back.
5/20/2010 9:06:30 PM • Amana ARB2217C... • Answered on May 20, 2010
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
4/13/2010 1:55:12 PM • Amana ARB2217C... • Answered on Apr 13, 2010
Amana ARB2217C Bottom Freezer Refrigerator Logo
40 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
freezer seems
  • Refrigerators
