20 Most Recent
i-mate SP5 Smartphone Questions & Answers
I-mate sp5(problem)
go start>settings>connections>there are number of options but go in connections.in MY ISP go in "add a new modem connection.fill up name for the connection which is given by service provider.select a modem from the list.go next.fill mobile or credit card number.go next.fillusername>password>domain.tap finish.i hope your problem will be solved.
How to set gprs settings
its dipending on your sim card
for airtet:
dail *567# and call
for aircel:
tipe wap in your msg and send 121
Need unlock code for my iphone keypad
There is no unlock code, you need to jailbreak and unlock it using "hacked" software available on the internet. Google would point you in the right direction.
No incoming sounds
check whether the phone is in silent mode.adjust the volume of incoming sounds by going into the sound settings and selecting incoming calls.
Key lock imate sp5
Press the power button on top, and select '3' Key Lock.
Unlock using (Left-Menu)button & *
You can setup a timed lock, but this requires a 4-digit PIN to unlock which is a hassle for normal use.
Problem re-I-MATE SP5M
hi thanks for using fixya!!
Try to remove the one you have installed, the bluetooth handset, and then try to make a call. If you are able to make a call. Perhaps, the device you have installed is not compatible with your Imate.
Imate SP5 sim/phone problem
Even though I have no tech experience, I figured it must be a setting problem between the phone and my simcard but could not work out how to resolve it. I eventually solved the problem myself by doing a factory default reset. Lost a couple of downloads but so what ! It works now and I'm happy!
I have broken my i-mate
Get the replacement screen from here
http://www.berlinkauf.com/Replacement_PDA_LCD-200968.html
Get the battery from here
http://bestcelldist.com/imate_sp5_battery.html
Here is the case holder(screen protector)
http://www.shop.com/28211087-37115894-p.shtml?sourceid=298
