20 Most Recent Acer Aspire 5500 5570-2609 Laptop Questions & Answers
Your media player might be having problems getting the video feed from the USB. try copying the file to your local disk and play the movie from there.
Acer Aspire 5500... | Answered on Oct 31, 2019
Arcade Deluxe is nothing more than a **** media center with a useless media player in it - get rid of it. If you want to play BR disks there are 2 options: either install a good codec pack like http://www.free-codecs.com/download_soft.php?d=5748&s=775 an use WMP or install and use VLC http://www.videolan.org/vlc/download-windows.html
Acer Aspire 5500... | Answered on Aug 16, 2019
If the card is compatible with Windows 2000, it probably is compatible with Windows XP.
If not, access the manufacturer's web-site, and download the device-driver for Windows XP for the device.
Acer Aspire 5500... | Answered on Jul 01, 2018
Hi friends,
"The file sysutil.dll is missing."
"Cannot start Metamail. A required component is missing: sysutil.dll. Please install the application again."
sysutil.dll error notifications may appear while using or installing certain programs, when Windows startup or even shutdown. sysutil.dll errors are caused by situations that lead to the removal or corruption of the sysutil.dll. In some cases, those errors could indicate mostly a registry problem, a virus or malware issue.
to Fix Sysutil.dll Errors
The sysutil.dll error message could apply to any program or system that might utilize the file on any of Microsofts operating systems including Windows XP, Windows 7, Windows Vista, and Windows 2000.
You can fix a sysutil.dll error and there are many ways to do it. A registry cleaner program can help by removing invalid sysutil.dll registry entries that might be causing the DLL error. The below utility is without a doubt the best one out there at the moment.
> Click Here http://filehippo.com/download_ccleaner/
Let me know if any further clarification is required. Hope it will help! Dont forget to rate the solution!!
Acer Aspire 5500... | Answered on Jun 22, 2018
I suggest you take it to a computer shop so either the keyboard can be cleaned or replaced.
Acer Aspire 5500... | Answered on Feb 05, 2018
Many users who updated their older operating systems to Windows encountered various problems. One of the most popular ones is the so-called black screen which may appear both after installation of the new version and in the middle of the updating process. While more advanced users can fix the problems with little effort, beginners face a certain challenge. However, do not give way to panic and call an expert home, because there is a very simple way to cope with the problem, though it requires some work to be done.
Very detailed article about it: https://hetmanrecovery.com/recovery_news/windows-10-for-dummies-why-black-screen-appears-and-how-to-solve-the-problem.htm
Acer Aspire 5500... | Answered on Jan 03, 2018
Try this..
Open Movie Maker
Goto TOOLS - OPTIONS
Open the Compatibility Tab
Remove the ticks from ALL filters EXCEPT the Microsoft ones.
If there are only MS filters, the remove the tick from those also.
Post back the results please =)
Acer Aspire 5500... | Answered on Dec 30, 2017
There are free software programs out there to disable touchpads when typing for example
When I had a laptop I used a free program called 'touchfreeze'
Worked well for me
http://touchfreeze.net/
Acer Aspire 5500... | Answered on Oct 19, 2017
You cannot chan ge SN of your laptop. SN of the laptop and SN of the motherboard are not supposed to be the same as for every component in your laptop has it's own SN being produced by different manufacturers even for one single laptop, and the laptop, as a machine built from those parts has it's own. SN is not changable in any way.
Acer Aspire 5500... | Answered on Aug 04, 2017
Step 1 Open the Windows Start menu by clicking on the icon in the lower left corner of your desktop.
Step 2 Click "All Programs," then the "Acer" folder.
Step 3 Select "Acer eRecovery Management" to open the utility. If a Windows prompt asks for permission to run the program, click "Yes."
Step 4 Click the "Restore" button in the pane on the left side of the program window.
Step 5 Click "Completely Restore System to Factory Defaults."
Step 6 Select the "Yes" option in the dialog box that asks you to confirm the action, and click "Start."
Step 7 Click "OK" in the second confirmation dialog box to restart the computer.
Step 8 Click "Next" in the warning window that appears after the computer reboots. This confirms that you realize restoring the computer deletes any data stored on your hard drive.
Step 9 Click "Next" again in the Restore Destination window, and click "OK" in the popup that gives you one last warning about deleting your data. The restoration process will begin.
Step 10 Click "OK" when the utility lets you know that the restoration is complete. The computer will restart, and Windows will finish the recovery process.
Acer Aspire 5500... | Answered on May 22, 2017
u mean to say, u r using wireless for internet access right.
Well if u r using XP, and if u r having some trouble in accessing internet, then there might some problem with the components of wireless card. so if u want to fix them, u can fix them with a simple trick.
Go to My Computer's Properties
Go to device manager,
open the tab named NETWORK ADAPTER.
u'll see ur wireless adapter listed. select it & select Uninstall.
Dont worry, just continue reading.
when u click on uninstall, u'll be asked whether u r sure to remove the device from ur computer, meanwhile u'll be given a marking space named UNINSTALL THE DRIVER FOR THIS HARDWARE.
Dont remove the driver, simply uninstall the wireless adapter.
Now its removed.
Now restart ur system, after it starts ur computer shows a ballon named, NEW HARDWARE FOUND and it will automatically install ur wireless adapter,
So ur wireless adapter is fixed by now.
and if u r using Vista, its quite easy there.
go to NETWORK & SHARING CENTRE
go to NETWORK CONNECTIONS u'll find 2 connections.
one will be named as Wireless something.
ENABLE it & click DIAGONISIS
after its completed, select RESET ADAPTER
Its done.
Hope it worked u out.
Thanks..
Acer Aspire 5500... | Answered on Apr 24, 2017
dear sir
5570z driver winxp download parmistion.
thanking
abhishek mohan
Acer Aspire 5500... | Answered on Mar 10, 2017
Uploading photos to Facebook is an easy way to share with your family and friends.
Facebook offers several options for posting photos, including your profile pictures, photo albums and photos posted to walls.
Facebook lets you choose files to upload from your computer or take a photo directly from your webcam.
If you want to post photos to Facebook from your webcam, you must first allow Facebook permission to access your webcam.
Navigate to Facebook's website and log in to your account.
Click "Photo" under the "Share" heading in the center column of your Facebook homepage.
Click the "Take a Photo with a webcam" link.
Click "Allow" when prompted by Facebook to allow access to your webcam.
Check the "Remember" box if you want to automatically allow Facebook to access your webcam in the future. Click the "Close" button.
Click the "No Filter" link in the top-left corner of the webcam preview window if you want to apply a filter effect to your photo before posting and choose a filter from the drop-down menu.
Click the "No Filter" link if you want to remove the filter.
Click the blue camera icon to take a photo.
If you want to retake your photo, click the gray "X" in the upper-right corner of the photo window.
Enter any text regarding the photo into the "Say something about this photo" field.
Click the "Share" button to post your webcam photo to Facebook.
You can also post a photo from your webcam directly to your profile wall by clicking the "Photo" link under the "Share" heading on your profile page
Acer Aspire 5500... | Answered on Dec 27, 2016
Concening the wireless connection....if you dont have a router of your own then you must have been sccidently connecting to someone elses that had no security.
What exactly did you do with the upgrade disk and what disk is it?
Acer Aspire 5500... | Answered on Nov 21, 2016
Try to uninstall your WiFi-card and reboot, allowing windows to re-innstall. If XP, Right-click on my computer, the properties tab, then periphials, locate your card and uninnstall. Restart. It has helped me before.
Acer Aspire 5500... | Answered on Nov 17, 2016
Here is your problem pasted again ingluding some of my thoughts. These thoughts and the answers to your questions are in CAPITAL.
There are exactly twelve children in Ryan's class. Only four of the children are boys. THAT MEANS THERE ARE 8 GIRLS. The following questions refer to a time when all the children are present in the class. THAT MEANS THE TOTAL PERSONS IN THE CLASS ARE 12 SINCE THERE IS NO MENTION ABOUT TEACHER. There are no visitors in the class. There might be more than one correct anwer to a question.
1. Which of the lettered statements must be true?
2. Which of the lettered statements cannot be true?
3. Which of the lettered statements could be true or not true?
a. There are twice as many girls as boys in Ryan's class. IS TRUE
b. There are eight more girls than boys in Ryan's class. IS FALSE
c. There are four more girls than boys in Ryan's class. IS TRUE
d. If Ryan is sitting at a table with all the girls, there are exactly nine children at that table. IS TRUE
e. If only three of the boys are standing on their heads, one of the boys is not standing on his head. IS TRUE.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Acer Aspire 5500... | Answered on Nov 06, 2016
Acer Aspire 5500 5570-2609 Laptop Logo
2,452 questions posted
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire 5315 windows vista home
  • Computers & Internet
