20 Most Recent
Amana ARB2517CC / ARB2517CB / ARB2517CW Bottom Freezer Refrigerator Questions & Answers
Compressor is HOT, coil is not warm
Check to see if the fan is running down in the back by the compressor, if it isn't put a small fan back there blowing on the compressor, also make sure the compressor is running you can unplug it and block the fan by the compressor wait a few minutes and plug it back in so you can hear the compressor to see if it is running. if it hums and then clicks you probably have a bad relay and overload assy.
Amana ARB2517CW the refrigerator used
The sound you are hearing is the overload clicking. The relay/overload is attached to the side of the compressor. Remove it and give it a shake - if it rattles than replace it. If the compressor still doesn't run with a new relay/overload than check your warranty for replacement of the compressor. FYI the compressor should still operate run with a faulty run capacitor but it will decrease it's efficiency.
However here is how to test your refrigerator's compressor relay though its not an easy job to perform….
Before working on your refrigerator, always unplug the unit or turn off the circuit breaker that powers it. You never want to work on it while it is plugged in because the compressor could kick on at any time!
Locate your compressor. It is usually at the bottom rear of the refrigerator. It is usually large and cylindrical. On the right side of the compressor you should see a box with wires coming out of it. In this box is where the compressor relay is located.
IMPORTANT: Some older refrigerators use a capacitor with their compressors. If yours has a capacitor wired to the compressor, it will need to be discharged prior to working on the unit. Take your 20-amp wire wound resistor (available from most electronics stores) and touch the leads of the resistor to the terminals on the capacitor. This will remove any retained voltage and eliminate the risk of backcurrent shock.
Remove the cover on the compressor relay box. The cover is usually held in place by retaining clips or tension clips. There are usually three components inside this box: the compressor relay, the compressor motor terminals and the overload protector. The compressor relay is the largest component and will either be wirewound or solid state. If the part is solid state, then you will have to have a professional test the part, as it requires specific equipment for testing. If you have a wirewound relay, pull it straight off of the compressor.
Use a pair of needlenose pliers to pull the connector off of the relay's terminal. Be sure to pull it off by grasping the connector and NOT the wire. Check both the wire connector and the compressor relay for any signs of corrosion.
After you dust the relay off, take a good look at it. You should see two plug-type terminals marked "S" and "M" and the slip-on terminal marked "L." Set your multitester to read ohms (usually the X1 or RX1 setting). Set the relay on a flat surface so that the "S" and "M" terminals are on the bottom.
Insert one probe of your tester into the "S" terminal and one in the "M" terminal. Your tester should have a reading of "zero" ohms. Keeping the probes inserted in the terminals, turn the relay over. You should hear an audible "click" and the tester's reading should change from "zero" to "infinity."
Turn the relay back over. Now, touch one probe to the "S" terminal and the other probe to the "L" terminal. The tester should read "zero" ohms. Turn it over again with the probes still on the terminals and the tester should read "infinity."
Turn the relay back over. Now, touch one probe to the "M" terminal and the other to the "L" terminal. The tester should read "zero" ohms. Turn the relay over with the probes still in place and the tester's reading should not change -- it will remain at zero ohms.
If your compressor relay passes this series of tests, then your relay is not the problem with your refrigerator. If it fails any one of these tests, then take it to an appliance parts shop and purchase a replacement. Replace everything back in its original position and be sure to remove the 20-ohm resistor from the capacitor before plugging the refrigerator back in.
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
Purchased a used Amana frig. Cosmetically great
Good day,
occasional buzzing sound appears to be the compressor trying to start and can't.
What you hear are probably the fans running.
On the side of the body of the compressor is a cover that houses the start relay, overload protector, and on some models a start/run capacitor.
These items can be removed and taken to any decent sized appliance parts house where they would be glad to test them.
If any are defective replace. If all check good, then it is probably an internal issue with the compressor itself.
To test the compressor itself properly, would take a tech with the proper testing tools.
Freezer Quit working
Hi, That clicking noise is the relay/overload trying to start the compressor. Is this under 5 years old?
They have had a lot of problem with these. I might suggest you calling Amana and inquire about the warranty.
If the warranty has expired, you can try to replace the relay kit.
If I can assist you further, please let me know.
Thanks
Vic
