20 Most Recent
Samsung LN-T4661F 46 in. LCD HDTV Questions & Answers
No audio output from speakers or jack
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
4/22/2017 11:57:50 AM •
Samsung...
Answered
on Apr 22, 2017
Right side of Samsung LN T4661F 46in LCD is blurry
hi this could be a tab/ribbon fault, there are ribbons attach to the screen at the top there's chips installed on them. when one is faulty they heat up and make the ribbon start to flex and move causing this fault, hope it helps
regards
shaun
5/16/2014 3:59:39 PM •
Samsung...
Answered
on May 16, 2014
How to repair tv with lines on display
the samsung LNt 4661F has been known to develope flex tab bond issues which will cause line to run across the screen and you can also gt darker bands that run across the screen when the tab bonds fail. usually flexing the screen frame or a light tapping will allow the lines to disappear when its warm if its a tab bond issue
4/24/2013 3:55:33 AM •
Samsung...
Answered
on Apr 24, 2013
