20 Most Recent Toshiba Satellite A135-S4527 Notebook Questions & Answers
Sound like a performance problem. Did you try updating your video and sound drivers?
You should also see if the Adobe Flash Player is properly installed as that is used for Youtube playback.
Toshiba... | Answered on Nov 08, 2019
why rent one pay it they quite cheap right now at least you will own but hey if you persist ask google "I want to rent a laptop" else come back here...............
Toshiba... | Answered on Aug 04, 2018
Fn+F9 is the hot key for enabling or disabling the touchpad
Toshiba... | Answered on Apr 15, 2018
hi K Smith.
Here are some troubleshooting steps that may help in identifying the issue.
- Start by doing a hard reboot, remove the battery and unplug its AC adapter then press and hold the power button for 20 seconds and see if it will boot up.
- If these will not work remove the HDD then boot it up and see if it will still get stuck at the BIOS screen or not.
- If it doesn't get stuck on BIOS and boot onto a black screen that means it's the HDD that is faulty.
- If it does get stuck on BIOS even without the HDD that means it's the motherboard that is faulty.
- Last trick you can try is to remove the CMOS battery for a second then put it back in.
- If all these will not work you'll need to send it for a repair if its still under the factory warranty
or.
1) Unplug the power cord --> Remove the battery --> Hold the power button for
60 seconds --> Connect the power supply then try to switch ON the laptop and
later put the battery back into the laptop.
2) If the problem still exists then get it checked out.
or read up some more at this link.
Toshiba satellite c660 stuck on windows splash Google Search
Toshiba... | Answered on Dec 08, 2017
It could be a sympton of display cable failure or the display has failed, try plugging into an external source such as a monitor or tv and then try booting, if you get a display then it is the notebook screen or cable that may be faulty, hope this helps.
Keith
Toshiba... | Answered on Aug 06, 2017
I would say that your McAfee is either not installed correctly or it has expired. If you right-click on the icon and open the program it will most likely tell you what it wrong.
I would suggest that you contact technical support for that product by going to www.mcafee.com to find the answer.
In my experience, when a program does not work someone else has had that problem and reported it to the company that wrote it.
The fact that there is an X on the icon tells you that it is not functional.
Toshiba... | Answered on May 10, 2017
Sounds like malware or a virus is on the computer. I would google Malwarebyte and run it. Then Quarantine the Malware and restart the computer. It should stop the issues.
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
Toshiba... | Answered on Apr 07, 2017
Did you reformat the hard drive? Try to turn off your computer and re-do your setup
Toshiba... | Answered on Dec 01, 2016
try doing a restore to when it last worked then let me know what happend.
Toshiba... | Answered on Dec 22, 2015
how to bio reset and boot for pendrive and install other window
Toshiba... | Answered on Sep 19, 2015
Well, I´m not sure which product key you´re looking for but this website (http://www.product-key.com/) helps you find it.
Toshiba... | Answered on May 20, 2015
draw the laptops rechargable battery and open the laptop completly and draw the cmos battery and reinstall it and you can reset the password
Toshiba... | Answered on Mar 26, 2015
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&rpn=PSAD6U&modelFilter=A135-S2276&selCategory=3&selFamily=1073768663
Copy and Paste the Link to your URL
Toshiba... | Answered on Mar 25, 2015
Is the speaker turned on? You must pair the computer with a working device.
Toshiba... | Answered on Nov 29, 2014
You need to contact McAfee about this, usually this requires online confirmation.
hi, I think this may help. what you need to do first of all is change the default player for DVD's from Toshiba Video Player to Windows Media Player, cant remember off hand how to do that but should be in manual, but try this. go to windows control panel, select 'Default Programs' and click on it, then select 1st option 'Set Your Default Programs' a list of all programs will come up, look for Windows Media Player and click on it, then choose one of the options on the right. The top one sets as default, the bottom one allows you to set file types to open with the program. this should work as it is telling your system to launch that program for DVD's etc, If you cant find your control panel, simply click Start and type it in the little box that appears just above it.
hope this helps
Toshiba... | Answered on Jun 23, 2014
There are generally three different types for firewire connectors. In the laptops its usually the mini contact(type 2) so is even on the camcorders. on the desktop PCs and MACs however it could be. either type 1 or the type 2. There is a thired type (B) which is less common.
The link shows all the types, male and female:
http://www.l-com.com/content/Article.aspx?Type=N&ID=95
Hope it helped
/BS
Toshiba... | Answered on Jun 16, 2014
Toshiba Satellite A135-S4527 Notebook Logo
1,247 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
satellite c55 a5308 bluetooth enable
  • Computers & Internet
