20 Most Recent
HP Officejet Pro L7680 All-In-One Printer Questions & Answers
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395
The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
Says printhead prblem,
Most generic inks will not work in this machine, If you are using genuine HP ink, you have gotten a bad printhead, if you are using generic ink you may have just ruined a new printhead.
The printer cuts off the
Yes, most likely your application's margin settings are incorrect. Try printing a test page - NOT from the application. If this is Windows, go to printers in control panel, right-click on the subject printer, choose Properties, then click the Print Test Page button. You should get the standard Windows printer test page with the logo at the top and all the printer specifics below. If the test page is also cut off, look around in the HP-provided software for any margin and/or page size settings that are incorrect, such as A4 paper when it should really be Letter size.
I bought and replaced the
please take your print head and get it tested or get it replaced, or you could take your printer to a local HP service centre and get it checked, rather than trying to fix it yourself you mite damage the sensors for the print head.
HP printer error code 0003
please clarify what is the exact thing the printer is doing whenever you get this code>where do you see this code isiton the computer or on the screen of the printer>this might have something to do with the ink systems
My HP Officejet 4500 won't
I also faced the same problem. You can try the following steps to fix this issue:- Check ink cartridge- Reset your printer- Clean print-heads- Check the printer's color optionYou can visit the following link to read these steps in detail:https://www.techsolutionforall.com/blog/facing-issues-hp-officejet-4500
Error code 0005FBB6
Turn on the HP All-in-One.
Disconnect the power cord from the back of the unit.
Press and hold the # and 3 buttons simultaneously.
While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
Continue holding the buttons until the Power button blinks.
Follow the instructions that display on the unit to select the language settings.
Then when that's done, try printing, or copying items. If its still not working, check the ink and change those out and this should fix it.
Cloud Striver
If you have further questions email
[email protected]
How do I remove stuck paper
Please follow these steps:
•1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
•2
Turn off the printer.
•3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
•4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
•5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
•6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
•7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
•8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
•9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
