20 Most Recent Lexmark X5470 All-In-One InkJet Printer Questions & Answers
The 1203 error indicates either a communication problem between your cartridges and your printer or a short in one of the cartridges. Please follow the steps below to identify and fix the issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. Then try to print a document again to verify that the problem is fixed.
Lexmark X5470... | Answered on Jul 15, 2019
Microsoft Paint ----> 'File' -----> 'From scanner or camera' (while the Lexmark is in scan mode). Just tried it and it really works.
Lexmark X5470... | Answered on Apr 12, 2019
You should call on ((+1-800-585-2494 )) Toll Free Lexmark and get help for Lexmark.
Lexmark X5470... | Answered on Oct 10, 2018
Try to uninstall your existing printer driver. Then, reboot your computer after the uninstall process.
Once your computer comes back on, visit the Lexmark website to download the Lexmark X5470 printer driver for Mac 10.6 at http://bit.ly/yRg5X8.
Lexmark X5470... | Answered on Feb 13, 2018
Karen,
Sounds like your card may have went bad. A good way to check this would be to use a different memory card. Hope that helps! Good luck!
Sincerely,
Jeremiah
Lexmark X5470... | Answered on Dec 28, 2017
What type of printer you're using?
Lexmark X5470... | Answered on Dec 19, 2017
Please find a full software driver for your printer and also it has to be compatible with your OS ( operating system ) the full software has the scanner and printer software in it . Once u download ! Then install . Start enjoying your device and problem won't occur again
Lexmark X5470... | Answered on Sep 06, 2017
Push and hold the 'Start" button after it fires up to turn it off. It should stay off after that. If that doesn't solve your problem then if you have it hooked up via USB cable just leave it unplugged until needed. If you are running it through your WiFi you can always just change your WiFi setting to Manual instead of Auto.
Lexmark X5470... | Answered on May 23, 2017
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dellâ„¢ 964 or 966 Printer
To reset factory defaults on the printer, perform the following steps:
1. Press the down arrow button until Maintenance is highlighted and press the Select button.
2. Press the down arrow button until Reset Defaults is hightlighted and press the Select button.
3. The printer displays a confirmation message. Highlight Yes and press the Select button
Note:
Some settings such as phone lists, time, date, and country are not changed.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Lexmark X5470... | Answered on May 02, 2017
Have you tried plugging it in without surge protector? Also, open front cover and make sure there isn't another power switch in there. Some Lexmark's have a push power button on control panel....but have an actual physical power switch on the inside of the front cover. So it may not be fully powered off. I am a Lexmark Tech, I've seen this on a few models.
Lexmark X5470... | Answered on Mar 20, 2017
hi u can buy them on E/BAY..type in e/bay search---- 2- prong AC power cord cable lead for Lexmark printer scanner ac adaptor charger cost AU $3.20 good luck
Lexmark X5470... | Answered on Feb 01, 2017
I hada the same problem. I used the settings on the actual printer rather than through the software to input the information it needed and It works fine now. I was able to set it up on my husbands laptop without any problems, I just added his laptop through installing the software on his laptops as it had picked up the signal and was showing in the Network and sharing centre on Windows Vista premium. Hope this helps. I think you need to take the wire out now and now load it as wireless. You need to use the wire first to connect then take it out to connect to the wirelss network. My router is a Sky router.
Tiptap
Lexmark X5470... | Answered on Sep 11, 2016
Lexmark X5470 All-In-One InkJet Printer Logo
1,734 questions posted
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
lexmark scanner cannot retrieve
  • Office Equipment & Supplies
