20 Most Recent
HTC S620 Smartphone Questions & Answers
Can't send email with bellsouth account
The simple solution is set up a Gmail account... Bellsouth will not let you send email unless you are at home directly connected to their server... because of spam issues. Do like I had to and just receive your mail from bellsouth but send replies from your gmail account or just use gmail all together.
9/28/2018 5:10:27 AM •
HTC S620...
Answered
on Sep 28, 2018
Unlocking code for htc s620
hi you can get the unlocking code from here
mobile-unlocker here they ask the following details before rendering the codes they are
mobile model
country from where you brought the mobile
provider to which the mobile is locked
imei number of the mobile
finally they will provide the unlock code .
12/28/2017 12:08:47 PM •
HTC S620...
Answered
on Dec 28, 2017
My HTC S620 stays on second start screen
Hello, These methods have been confirmed on my phone with both T-Mobile's ROM and Excalibur (S620 original ROM) Remove any memory cards before starting this process.
With OS:
1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
Without OS:
Turn the hand-held
off, hold the two soft keys (the dashes to the left and right of the phone buttons)
hold the power button for 1-2 seconds and then release the soft keys. It should
prompt you to clear storage. The “send” button is considered as the
green phone button.
Let
us know if you have any other questions. If this information was
helpful, please take a moment to rate the solution. Thank you.
2/14/2014 1:22:44 AM •
HTC S620...
Answered
on Feb 14, 2014
How can i connect driver via usb to htc s620
I am not able to access my HTC DASH with my computer, meaning it doesn't see at all, i think I mess up the program and lost the driver or something. how can i connect driver via usb to htc s620 smartphone.how can download htcs620 driver?
7/24/2013 4:36:28 AM •
HTC S620...
Answered
on Jul 24, 2013
Pulling htc s620 battery soft reset
You can do this:
- remove the battery
- press at the same time the soft keys (the 2 keys just under the screen with the symbol "-"), and do not release
- replace the battery
- always press the soft keys, press the power button (5 seconds)
- release power button
- release the soft keys
- s620 will not start windows, but open a black window
- press the send key (green telephone) to restore factory default configuration.
- s620 will enter in windows and work normally.
good luck
12/15/2011 4:01:55 AM •
HTC S620...
Answered
on Dec 15, 2011
How do i type a word document directly on my htc dash or s620
It is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is possible that the fault is relative to the software and will need a reinstallation. Possible hardware issue cannot be ruled out.
11/21/2011 11:29:40 AM •
HTC S620...
Answered
on Nov 21, 2011
Ive locked my phone and
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
8/18/2011 8:50:57 PM •
HTC S620...
Answered
on Aug 18, 2011
