20 Most Recent Garmin Nuvi 660 GPS Receiver Questions & Answers
2answers
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
12/16/2022 7:06:25 PM • Garmin Nuvi 660... • Answered on Dec 16, 2022
I have a garmin nuvi 660. The touch screen not working
Select Settings from the Menu Page. The "Settings" tab may show a wrench icon to the right of the main screen or at the bottom of the main screen depending on the model of your Garmin GPS. Touch Display from the Settings menu. Click Touch Screen from the Display menu and press Recalibrate. Follow the prompts to realign your touch screen so it responds correctly to your touch. Learn more How to troubleshoot your Garmin issue.
12/2/2022 7:13:44 AM • Garmin Nuvi 660... • Answered on Dec 02, 2022
Garmin Nuvi 765T won't power-on or charge
When your Garmin GPS power not turn on or not charge on there are various reason behind. May be used the dead battery or damaged power cable to resolve these issue replaced the battery or power cable. When your Garmin GPs is not charged your screen show pending Garmin GPS map updates. To resolve these issue update, the latest Version of GPS Map updates. Also ,Read these Blogs : https://gpsmapzz.com/blogs/how-to-fix-garmin-gps-wont-charge-issue https://gpsmapzz.com/blogs/why-my-garmin-wont-turn-on-guide-to-fix-it Learn more how to troubleshoot your Garmin issue.
12/2/2022 6:50:35 AM • Garmin Nuvi 660... • Answered on Dec 02, 2022
3answers
I have a Garmin 885 the sceen does not work.
I recommend attempting a hard reset of your Garmin Nuvi 885.
Then I would upgrade the system software to the latest version. This often brings back unresponsive Nuvis.
Perform the Hard Reset
  1. Power the unit off.
  2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  3. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  4. Press "yes" and the unit will reboot.
Upgrade the System Software
The upgrade software is a download available from Garmin. Installation steps are detailed here.
I hope that helps.
11/18/2022 7:12:16 AM • Garmin Nuvi 660... • Answered on Nov 18, 2022
GPS turns off unexpectedly
If your GPS is suddenly shut off check your device may be set to battery-saving mode. If you faced a battery issue, then replace the battery. Check out the replacement guide for more information on how to replace the battery. After that, try plugging in the GPS to see if it will stay on. If that does not work, check if the cable is working. You can test this by trying out a different cable. Learn More: https://bit.ly/3V9aePi
11/15/2022 7:47:26 AM • Garmin Nuvi 660... • Answered on Nov 15, 2022
2answers
How to install map to garmin nuvi 205w
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Just so you know:
Sorry, no free maps. I know I've tried. You either live with the old map or buy the latest version.
I bought the life time maps updates and I'm glad I did.
I've updated my maps at least 6 times.
New maps are about $70.
Life time maps are about $99 (when I bought mine)
BUT FIRST make SURE you have the latest software in YOUR computer and in YOUR Garmin before you load any maps.
You can get that FREE at Garmin here:
Normal 0 false false false MicrosoftInternetExplorer4 To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
11/10/2022 7:46:19 AM • Garmin Nuvi 660... • Answered on Nov 10, 2022
2answers
Update for Garmin nuvi 200
I just got a Garmin Nuvi 660 and cannot figure out how to charge the unit. Help!!!!
9/19/2022 11:13:35 AM • Garmin Nuvi 660... • Answered on Sep 19, 2022
7answers
How to activate my nuvi 660 using my mac and itunes or audible.com
I had the same problem and was able to resolve it using the procedure (listed below) from Audible technical support.  It's wordy, but the long and short of it is that you need to activate the Nuvi on a PC machine, then you can use it on the Mac.  To transfer files, open iTunes audiobook window, then drag your books of choice from that window to the Nuvi icon on the desktop.  I had no problems using this procedure.
Thank you for contacting Audible.com. On its behalf, I would like to apologize for any inconvenience and I am most committed to satisfying and resolving your inquiry to the fullest of my abilities.
As per your email I understand that you wish to use your Garmin GPS with Audible on your Mac.
Unfortunately, the Garmin is not supported on a Mac with Audible audiobooks unless it is first activated on a Windows PC. If you have access to a Windows PC please follow the requested steps below to activate it on a PC first. Once successfully activated you will be able to use your Mac to transfer your audiobooks onto it.
If you have access to a Windows PC to activate your Garmin GPS through the Audible Manager software please do the following to get started.
Make sure Audible Manager is installed in your PC, otherwise please go to: Audible Software page ( www.audible.com/software ) and download the version for Download for Windows 2000, XP, or Vista. Select Run or Save. During this installation process, a message: "If you already own an Audible Ready mobile device, please select it from the choices below", will prompt, please select Garmin GPS Devices from the list.
If Audible Manager is already installed on your PC: Launch Audible Manager, click on Devices > Add new device. You will be asked to connect to the Internet. Click Yes to connect. From the list of devices, select the Garmin GPS Devices, and click ok.
Once installed successfully now please follow the requested steps to activate your Garmin Nuvi using the Audible Manager software.
Ensure that the device is connected to the PC and Internal Memory is selected to activate the Main Memory of your GPS. Please note you may transfer your audiobooks onto the SD card as well if you have one.
Right-click the Garmin plugin in the bottom left corner of Audible Manager ( below Mobile Devices ) and choose activate.
After entering your username and password, click ok.
Once your Garmin has been successfully activated using a Windows PC you may now use your Mac to transfer your Audible audiobooks to your Gramin.
Before you can transfer your audiobooks on to your Garmin device please follow the requested steps below to download your audiobooks.
Please log into your Audible Account, Click on My Library on the top of the page next to Home, Once you are in your online library towards your right hand side, you will find a tab called "Download It". This will start your download action from our server to your computer.
This will download the selection onto your desktop and open iTunes. If the file downloads to your desktop, double click or drag the file into the iTunes library.
Connect your Garmin device to computer.
Drag the book from iTunes onto the Garmin device.
Playing Audible Files on Garmin Nüvi
From the Main Menu after powering on the Nüvi, select Travel Kit > Audible Book Player.
You can locate the title in the Audible Book Player by clicking on the Browse button. You can search all titles, or by Genre, Author, or Narrator. Select the category you would like to search by, and select the title. Press the Play button to begin enjoying your Audible selection.
Title: Garmin Nüvi Installation
URL: http://audible.custhelp.com/cgi-bin/audible.cfg/php/enduser/std_adp.php?p_faqid=3239&p_created=1144186251
Unfortunately, at this time we do not have any information regarding the Garmin GPS being supported on a Mac in the future. However, I will be glad to forward your email address to upper management so you are notified once the Garmin GPS is supported on a Mac.
As always, I hope I have met all your needs and requests, as it has been a pleasure assisting you today. If I could be of any further assistance, or answer any further questions, please let me know and I'll be happy to do so.
I appreciate and value your business as an Audible customer.
Here at Audible, we truly value and appreciate your business; if you need further assistance, please respond to this email or if you wish, please provide me with a contact number and the best available time to reach you.
For additional questions, how to contact us and hours of operation, please visit us at: www.audible.com/contactus
Sincerely,
Hakime R.
Audible Customer Support
5/16/2022 3:58:32 AM • Garmin Nuvi 660... • Answered on May 16, 2022
4answers
I bought at Garmin Nuvi
It's strange if the plug doesn't fit the cigarette lighter socket. They can be a tight fit so if you find it a little big for the socket try putting pressure on it to push it in. If it absolutely won't fit you can buy cigarette lighter plugs in car accessory shops. If you can get one that does fit you can cut the one that's on the lead off and fit the new one.
If you cannot get any plug to fit you can get the lead wired permanently into the car. Any garage would be able to do it for you.
9/29/2020 6:42:49 PM • Garmin Nuvi 660... • Answered on Sep 29, 2020
11answers
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
3/11/2020 11:09:18 AM • Garmin Nuvi 660... • Answered on Mar 11, 2020
Call 1-8O5-225-669O GPS/GARMIN Update-Install-Download-Fix We are 24 Hour Available Call Now For Help
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
just model number is different but the system is same
hope this helps
11/17/2019 9:30:04 PM • Garmin Nuvi 660... • Answered on Nov 17, 2019
Voice on Garmin Nuvi 660
The GPS has gone bad. I would say just the speakers, but with bluetooth going out also, it is time for a new unit.
11/13/2019 4:49:30 AM • Garmin Nuvi 660... • Answered on Nov 13, 2019
How do work stoped gps garmin
I had the same issue, i'm still using in 2019.. and all in Sudden no signal started appearing.. I tested all possible methods, but none of them worked.. today in morning, I opened my garmin's GPS module, and the cable was out form the circuit.. I fixed that back and wow.. it worked great. You should have tried this too.. like open the garmin screen, and then check if cable is fully afixed or not.
10/17/2019 9:19:54 AM • Garmin Nuvi 660... • Answered on Oct 17, 2019
2answers
Nuvi 660 touch screen not responding...
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
9/10/2019 7:21:45 PM • Garmin Nuvi 660... • Answered on Sep 10, 2019
2answers
Memory Full - Garmin nuvi 200
Turn off the device, push and hold in right-down corner on the display, and turn on the device. Hold your finger on the display, until you see "Do you really want to erase all user data?" message. Then click "Yes"...
Hint:
All private data will be erased. The user POI's too. You can backup the file G:\Garmin\gpx\current.gpx before erasing procedure.
6/3/2019 6:54:20 AM • Garmin Nuvi 660... • Answered on Jun 03, 2019
8answers
White "press dot" screen
The actual answer is to press the dots, but use a dull plastic tool that fits "within" the dot. Otherwise the width of your finger is too imprecise to calibrate the dots and screen.Hope you, and others, get this and try it. It works. I just discovered it and did it, successfully after only about 10 presses.
5/6/2018 12:49:05 PM • Garmin Nuvi 660... • Answered on May 06, 2018
0answers
Map upgrade
Be the first to answer 10/29/2017 9:42:02 AM • Garmin Nuvi 660... • Posted on Oct 29, 2017Be the first to answer
Nuvi 200 can't see screen
They are not that bright light conditions. But if you cannot see anything at all something is wrong. Try it in a completely dark room and see if you can see the menu for settings - brightness.
9/21/2017 9:17:42 PM • Garmin Nuvi 660... • Answered on Sep 21, 2017
GPS trubleshoot
You need to contact Customer Support. http://www.garmin.com/en-US/company/contact
9/21/2017 1:36:45 AM • Garmin Nuvi 660... • Answered on Sep 21, 2017
Garmin Nuvi 660 GPS Receiver Logo
1,531 questions posted
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
nuvi Garmin
  • nuvi Garmin
Most Popular Question
nuvi 200w map download sd card
  • GPS
