20 Most Recent Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Questions & Answers
Operating pressures for 134A refrigerant system
I would go for 40 on the suction and 150 discharge, or divide the locked rotor current by 6 and charge so the current is 1/6 of the locked rotor current of the compressor, or by temperature/pressure relation 110* discharge and 35* suction, or get the suction line sweating. The best way is to remove all the refrigerant and then weigh the refrigerant the system is designed for on these critical charge appliances.
10/21/2019 11:57:07 AM • Amana 22.6 cu.... • Answered on Oct 21, 2019
Amana refrigerator has stopped making ice
ice maker has stop making ice, but you can hear the water going to it, i think it might be frozen up. what is the best way to thaw it out with out turning the whole fridge off.
9/3/2019 11:19:29 PM • Amana 22.6 cu.... • Answered on Sep 03, 2019
Water,ice, crushed ice in door NOT working- Amana side by side
the lighting switch has poblem.
10/10/2017 7:29:08 PM • Amana 22.6 cu.... • Answered on Oct 10, 2017
0answers
Fridge and freezer not cooling properly!
Sounds like a problem with defrost system , It could be one of there components , timer, heater, or defrost thermostat. try advancing the timer, down at the lower area behind the grill. with a screw driver by putting it into the dial advance and turn it till it clicks and the unit shuts off. now you should see red glow at bottom of back panel in freezer or here sizzling . if this does not happen then it will be the heater or the thermostat.
4/27/2017 11:08:22 AM • Amana 22.6 cu.... • Answered on Apr 27, 2017
2answers
I have purchased amana international model srd 522
you can find out what will be replacement part number in any HVAC/R supply store. This is how bad compressor looks like inside.
6/12/2016 3:05:58 AM • Amana 22.6 cu.... • Answered on Jun 12, 2016
Pried the door open breaking the little white
The cheap way is also the dangerous way. Without the safety lid switch the washer will keep spinning when your little girl opens the lid and reaches inside and gets pulled in or her arm broken. You can bypass the switch by taping the two wires together.
For just a few dollars you can buy a new switch and install it yourself.
6/11/2016 11:44:32 PM • Amana 22.6 cu.... • Answered on Jun 11, 2016
Front Fill water dispenser suddenly stops
Not totally up with that Amana but just check you have not inadvertantly set it up to fill at a certain level, low, meduim, high etc.
10/26/2015 3:10:57 PM • Amana 22.6 cu.... • Answered on Oct 26, 2015
2answers
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
2/18/2015 10:57:35 PM • Amana 22.6 cu.... • Answered on Feb 18, 2015
Where is the door valve located?
By 'door valve' it is assumed you are referring to the ice and/or water dispenser operation. If so, it is located behind the panel covering the door opening where the fill mechanism is located. This is typically held in place by clips, molded into the panel and the valve or dispenser opening is a solenoid. You would greatly benefit through the assitance of an appliance repairman.
2/14/2015 3:31:29 PM • Amana 22.6 cu.... • Answered on Feb 14, 2015
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
705 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
per mark egans advice door valve located
  • Refrigerators
