20 Most Recent Amana ABB2223DES Stainless Steel Bottom Freezer Refrigerator Questions & Answers
The freezer is working extra well but the fridge is not getting cold even though it's set at 7
Check that the vent opening inside the fridge is not blocked. Depending on the age, some of them now have a filter that needs to be changed periodically. RepairClinic.com or Sears sometimes are able to give you an answer over the phone as to what else to check.
2/4/2018 7:38:09 PM • Amana ABB2223DES... • Answered on Feb 04, 2018
2answers
Poping the curcuit braker
Your compressor is bad .Need to replaced, a way to test is unplugged the compressor and see if it stays on
12/28/2017 3:23:17 PM • Amana ABB2223DES... • Answered on Dec 28, 2017
On several occasions, I've emptied, unplugged
Good Afternoon, My name is Houston and thank you for using FixYa! Your defrost system is made up of three components: defrost heater, defrost thermostat and defrost timer/control board. Since you have the ABB2223DES Amana the defrost timer is incorporated into the electronic control board (P/N: 12868513) which is located behind the control panel in the refregerator section. Unfortunately, it is in the $100 range, so let's hope that it is either the defrost heater (P/N: 67001794) - approximately $30 - and is located on the right side of the evaporator (the coils in your freezer section). If you have access to an ohm meter, you can test it by disconnecting and doing an ohm check - anything but an open or infinity reading usually means it is good. The last item is the defrost thermostat which is located near the evaporator (P/N: 12001937). It can also be checked with an ohm meter and the normal readings are 28-48 ohms. 10_4_2011_7_26_31_pm.jpg
10/4/2011 7:30:27 PM • Amana ABB2223DES... • Answered on Oct 04, 2011
Freezer is continuing to run and is forming some
You have a defrost problem. If you drop the back panel and have a full coil of ice. Then you have a defrost problem. If you only have half of coil of frost. Youhave a sealed system problem. More than you can handle you will need a tech. Ok if you have a defrost problem you thaw with a hairdryer. You should unplug and melt all the frost. Then you have about 7-10 days that the box will work. This will allow you some time to get it fixed. Hope this helps
8/22/2011 8:56:35 PM • Amana ABB2223DES... • Answered on Aug 22, 2011
Refridgerator is not cold.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8/2/2011 2:52:17 AM • Amana ABB2223DES... • Answered on Aug 02, 2011
Freezer has fuzzy ice, refrigerator not cooling at
hi,
Sound like a you have a door seal problem, if you get warm air in a freezer for too long will cause the air to crystalize and look like someone took a snow blower and blow it inside. Simple repair is to empty unit a unplug unit to thaw completely, but this could take 24 hours or so to do this. and towels inside unit to prevent leaking on to the floor. Either way you need to remove the frost so the unit will start working again.
After clearing the ice out, you will restore air flow inside the unit and things should return to normal, also check door seal to assure complete seal is made to prevent this in the future..
Good luck, be-careful it can contain all lot of water, for water the floor..... I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
7/21/2011 12:54:51 PM • Amana ABB2223DES... • Answered on Jul 21, 2011
I have an Amana bottom freezer PARB2117BS1 and it
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
6/3/2010 12:11:46 AM • Amana ABB2223DES... • Answered on Jun 03, 2010
Fridge section not cold enough
bad defrost times and or heater look nere the cold control timer is close buy it might be hiddin if you find it use a flat screwdriver and turn it slowly till you here frig turn off and lissn for heaters to come on you will hear them sounds like it shorting out sound
6/26/2009 10:52:19 PM • Amana ABB2223DES... • Answered on Jun 26, 2009
Our refidgerater is not cold enough running at about 50 degrees
hows the freezer?? is only the refrig warm and freezer still frezzing?? if so id open the freezer door and listen for a fan motor, it should be spinning to circulate air to the top sect(refrig). if not on sounds like a bad fan.. if the fan is on but the rear panle is completly iced over, sounds like a defrost issue
11/16/2008 3:19:40 AM • Amana ABB2223DES... • Answered on Nov 16, 2008
Amana SXD2252 side by side ice maker stopped, now leak on floor
ck here... https://www.appliancepartspros.com/repair-help/amana-refrigerator-sxd22s2w-repair/sxd22s2w-leaking.html But before throwing parts at it give their tech 877# a hollar.. Best to you
9/4/2023 5:56:53 PM • Amana... • Answered on Sep 04, 2023
Amana ARB1917CSR 18.5 Cu. Ft. Plus Refrigerator. What is the HP of my compressor, which Supco relay and run capacitor?
What tends to happen is that service techs have certain common generic parts in their van, and rather than ordering a part to fit and have a return visit, they fit what they have. Parts seem to be readily available. The compressor is listed but no HP Specs. The bottom show another model and that R134A (1/4HP) is different to R134 (1/5 HP). https://www.google.com/search?q=amana+arb1917csr+parts+diagram https://www.google.com/search?q=Tecumseh+TP122AR003B8 ..
7/27/2023 6:43:23 PM • Amana... • Answered on Jul 27, 2023
3answers
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM • Amana... • Answered on Jun 20, 2023
Possible cause of Amana refrigerator making a constant clicking/noise?
Sharla, It could possibly be the ice maker rod that tells the ice maker whether it's full or not. If it's in the down position it wants to make ice and it'll make a clicking noise. Lift the rod up if it's down. Hopefully this helps!? Best to you.
4/21/2023 7:28:31 PM • Amana... • Answered on Apr 21, 2023
3answers
What year is my Amana refrigerator, Model # ASD2522WRB06?
I'd like to know how you determine the age based on the info inside my Amana. I double checked the numbers. Model AFI2538AEB4 Serial KY2886165
3/4/2023 11:22:10 PM • Amana... • Answered on Mar 04, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
  1. Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
  2. Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
  3. Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
  4. Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
  5. Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM • Amana... • Answered on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM • Amana... • Answered on Jan 14, 2023
Where is the defrost timer located in Amanda Model SXD2252W
check to see if defrost fan working
10/19/2022 2:58:33 AM • Amana... • Answered on Oct 19, 2022
Amana ABB2223DES Stainless Steel Bottom Freezer Refrigerator Logo
14 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
our refidgerater not cold enough running
  • Refrigerators
