20 Most Recent
Amana ABB2527DES Stainless Steel Bottom Freezer Refrigerator Questions & Answers
Unit started making a buzzing
What do mean run the service test and everything seemd to check out.
If you mean electrical parts like compressor, relay, capacitor, thermostat, defrost timer, then the only thing remains is that you had a greon gas leak so the compressor work fine but without cooling.
You can confirm this by touching the in and out piping from compressor in will be cold out will be hot if their room temperature then you have complete freon leak.
In this case the things is not good since the leack is most posibly on the condenser the fins and coils you have describe and due to cleaning forced the leaking faster.
So now you need to make a good estimation before proceeding with fixing it or thik for a replacement.
You should ask for an estimation from your local technician for condenser replacement, freon leak investication and fixing and freon gas charge and freon filter replacement. All these thing need special equipment experience so if you wil be charge more than the half the price of a new replacement then our advice is to proceed with a replacement since freon leak is not secure that is one point only and not so easy to find and fix too.
Good luck
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
The ahndle on the freezer door is off can i fix it
most of these units have set screws that are tightened with an allen wrench the screw is on the bottom of the handle on eihter end of the handle hope that helps. if this doesnt answer your question if you would post a complete model number off of the unit I could look it up and be sure. thanks Peyton
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM •
Amana...
Answered
on Jun 20, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
- Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
- Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
- Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
- Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
- Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM •
Amana...
Answered
on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM •
Amana...
Answered
on Jan 14, 2023
