20 Most Recent Amana AFD2535DES French Door Refrigerator Questions & Answers
2answers
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
7/13/2021 4:07:13 PM • Amana AFD2535DES... • Answered on Jul 13, 2021
5answers
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
2/2/2019 9:51:57 PM • Amana AFD2535DES... • Answered on Feb 02, 2019
Hi, I have a amana af12538aes french door refrig. Starting this am, the control on the door does not deliver ice only cold water from the ice button. The ice maker is making ice. Is this a control
Is the display flashing when you try and use it or can you hear the dispenser door opening and closing rapidly (clicking or clapping sound)? These are prone to the board going bad and losing the dispenser. Is the "ice" light lit on the dispenser? The touch pad could be bad too. Do you hear the auger motor turning the ice when you press the dispenser? or just the "shhhhhhh" of the water coming out? If there is ice in the bucket then that is not the problem. Dump it and listen if you hear new ice drop to verify. There is no such part called an "ice element". Ice maker-yes.. Heating element-yes.. Ice dispenser-yes pd_0046_464_67006955-3dvc3rq02kdqjihqd3tusqf5-3-0.jpg
4/10/2018 7:16:54 PM • Amana AFD2535DES... • Answered on Apr 10, 2018
Amana french door refrigeraor section won't cool? Amana french door refrigeraor, less than 4 years old, refrigerator section becomes warm. If I defrost the vents in the back of the freezer sec
I would say you have a bad jazz board,do this open the right hand side door of the fridge,you'll see on the touch pad the up and down arrows,hold the light switch in and press the down key three times,let go of the light switch press the down button again and i think it says like s and p can't remember but press the down one more time and you should see 4 and 4 or whatever settings you had if you see this close the door,open the freezer, by doing what i told you you manually put it into defrost,if you hear the compressor running the board is bad part WPW10503278 and i have to tell you i've changed quite a few of these boards.also if the strip between the doors are hot check you coil on the bottom,usually when this happens the condenser coil is blocked with dust or the condenser fan isn't blowing,if you ever find the fan not blowing you can get a house fan and blow it onto the compressor and coil this will keep it cool until you change out the fan motor and you won't loose any food but that's another day.your coil might just need to be cleaned or the jazz board could be causing this because the compressor is running longer than it should.if you unplug the fridge,melt out all the ice off of the coil as best you can but the more the better you'll be able to use the fridge like normal for like 10 to 12 days then the coil will freeze up again so order the board melt out the ice with a hair dryer and you should be fine,if you need a hand programming the new board let me know i would tell you how to do it but i don't know if people are getting my answers nobody writes back,so open the freezer door,open the right side door,hold the light switch in,push the down button three times,let go of the light switch and push the down pad again and one more time you should see settings again,close the door,if compressor is running the board is bad. https://www.youtube.com/watch?v=HUoGLZYv... one more thing if you remove the bottom kick plate there should be a tech sheet either folded up and it's in the kick plate or it's in a plastic pouch taped up to the floor check right side but could be on left too and clean the coil while you're down there
1/25/2018 3:05:15 AM • Amana AFD2535DES... • Answered on Jan 25, 2018
2answers
Fridge doorhandle bracket
Possible the source of the trouble you are having is the bracket might not be available or available separately. Most parts lists have an exploded drawing showing all the parts and these are an invaluable aid to obtaining the correct spare parts. I suggest you ask the service department to fax or email a drawing to you.
3/28/2017 4:02:42 AM • Amana AFD2535DES... • Answered on Mar 28, 2017
2answers
The refrigerator compressor unit never stops, How can I fix this?
There a number of reasons that ice forms on the evaporator coil. One is no air flow or not enough air flow over the coil. Another reason could be the unit is not going into defrost. There will be some ice on evap coil most of the time, but the defrost cycle should remove the ice. If there is not enough air flow across the coil to take away the cold, the coil will build up ice. I would check the defrost cycle and make sure there is not an obstruction in the circulating fan system. On the older refrigerators you could turn the defrost timer to defrost, but the newer models have circuit boards, and I am not sure how to force the defrost.
5/15/2015 3:31:39 AM • Amana AFD2535DES... • Answered on May 15, 2015
0answers
Defrost
Be the first to answer 4/12/2014 3:45:11 AM • Amana AFD2535DES... • Posted on Apr 12, 2014Be the first to answer
The refridge is warm and the freezer is ok. this
the evaporator coil is frozen. i have had this problem for a while. i just figured it out. i believe the compressor is not shutting down. everone else is talking about a bbad fan but that might be a symptom of a frozen coil. i am further investigating.[email protected] (self proclaimed worlds best troubleshooter)
4/11/2014 4:17:15 PM • Amana AFD2535DES... • Answered on Apr 11, 2014
0answers
No water
Be the first to answer 3/27/2014 3:55:19 AM • Amana AFD2535DES... • Posted on Mar 27, 2014Be the first to answer
Need to level refridgerator
there is two adjusters at the front corners of the fridge
1/13/2014 4:03:23 AM • Amana AFD2535DES... • Answered on Jan 13, 2014
Amana AFD2535DES French Door Refrigerator Logo
214 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
  • Refrigerators
