20 Most Recent Amana ASD 2624 Side by Side Refrigerator Questions & Answers
Amana asd2624hew water dispenser drips
With the water dispenser is dripping the cause of that drip is the water inlet valve...its not fully closing yet staying up a wee bit and water is seeping through it into the the dispenser. To repair it the water valve needs to be replaced.Its in the rear of the refrigerator and the unit needs to be pulled from the wall and remove the service panel that covers the compressor and such...the valve will be on the left side. The part number for that water valve is 67005154 it could be purchased at your local appliance partstore or online at; searspartsdirect.com apdepot.com partselect.com
apwagner.com repairclinic.com while behind the refrig. replacing that water valve be sure to also clean all the dust from the coil on the righ side of the compressor ( Clean that coil every 6 months as regular maintiance)
I hope i have been able to help ya fix your refrigerator,
GENE
10/4/2011 7:33:44 PM • Amana ASD 2624... • Answered on Oct 04, 2011
How do i change the
Water filter is located in the upper right hand corner of the fresh food side.
Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
9/15/2011 1:04:12 AM • Amana ASD 2624... • Answered on Sep 15, 2011
2answers
Amana refrigerator side by side freezing on bottom on both sides.
Evaporator fan not working
9/9/2011 11:36:58 PM • Amana ASD 2624... • Answered on Sep 09, 2011
My Amana side by side asd2624hes freezer is full
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
9/4/2011 12:53:22 PM • Amana ASD 2624... • Answered on Sep 04, 2011
I have a side by side on the freezer side water is
Do you see any frost or ice buildup on the back panel inside the freezer section? What is the model number that is listed in the refrigerator section?
8/20/2011 8:42:52 PM • Amana ASD 2624... • Answered on Aug 20, 2011
0answers
My amana fridge is not
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/8/2011 7:56:40 PM • Amana ASD 2624... • Answered on Aug 08, 2011
Bought from home depot today freezer works
give it time to work out any bubbles that may have got in the Freon,,
6/12/2011 11:55:08 PM • Amana ASD 2624... • Answered on Jun 12, 2011
Water dispenser in not flowing
There are only a few reasons your refrigerators water supply will cause this. Click Here=> ASD2624HES They are the water filter (If Applicable) Here=> UKF8001 water control valve=> 67005154 or water freezing before water gets to dispenser. Click here=> ASD2624HEW Use and Care Manual Then scroll down to page 18 in your PDF If you have not already downloaded Adobe Reader=> Adobe Reader X From there it is just easy to follow the user manual and instructions of how to check different components of your model. Check that someone has not crimped or folded your water supply line feeding your refrigerator. If you need more assistance I will be here to answer all questions, Thanks, Sea Breeze
5/18/2011 3:04:00 AM • Amana ASD 2624... • Answered on May 18, 2011
The fridge is freeezing at normal settings and the
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
4/26/2011 8:04:28 AM • Amana ASD 2624... • Answered on Apr 26, 2011
GE Ice Maker not working.....Water in the door is working......
the fill tube that runs into the back of the icemaker is most likely frozen up in the cabinet. use a blow dryer to warm it up and you should be back in business..
2/19/2011 8:34:10 PM • Amana ASD 2624... • Answered on Feb 19, 2011
I have an amana asd2626hew
did you connect dual valve correctly if not icemaker could be filling when you try to get water out of dispensor also a way to check if your dispensor paddle and switch test ..... otherwise possible plugged water filter or bypass cap not installed in filter head... is water supply on to water valve
1/28/2011 5:24:29 AM • Amana ASD 2624... • Answered on Jan 28, 2011
I have an amana side by side refrigerator n is not
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
12/26/2010 3:30:35 AM • Amana ASD 2624... • Answered on Dec 26, 2010
Amana ASD 2624 Side by Side Refrigerator Logo
336 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
change
  • Refrigerators
