20 Most Recent Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Questions & Answers
I just got my whirlpool fridge and I'm having the exact same problem! The blue cap appears stuck and I'm afraid I'll break it if I force it with a tool. Please post a solution if you get one - I'll do the same. Thanks.
Amana Easy Reach... | Answered on Jun 10, 2018
The smell is coming from the back of my refrigerator and it has been noticeable for about a month. It is the worst when the motor is running. The inside is fine; no smell. Any ideas?
Amana Easy Reach... | Answered on Apr 17, 2018
freon is oderless,the gas has no smell to it,what was wrong with the fridge?having sealed system work isn't cheap,was this a new unit?but the gas has no oder
Amana Easy Reach... | Answered on Nov 12, 2017
Turning it off & back on at the power point may stop the alarm but its telling you there is a fault.
Amana Easy Reach... | Answered on Jul 06, 2014
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Amana Easy Reach... | Answered on Sep 21, 2013
Most likely the coils under the refrigerator need cleaning. Unplug the refrigerator and remove the front, vented cover below the door. With a vacuum cleaner and crevice tool clean the coils off. It may also help the clean off the door gasket and apply a very thin coat of Vaseline. (Don't forget to clean the refrigerator edge that makes contact with the gasket.)
Amana Easy Reach... | Answered on Sep 20, 2013
Some models like yours came with a defrost control board and others came with a defrost timer. They should be found inside the fresh food compartment and behind the temperature control panel. You will need to inspect and let me know which you have. Unplug first. If the control board looks or does not look burned it could be bad. The timer can be turned clockwise until compressor stops and should remain stopped for about 25 minutes. and then turn itself back on. If these look good then we need to remove the rear panel inside the freezer and test the defrost element with one wire disconnected to check for continuity. Just to be sure the element has not burned out. The defrost thermostat is connected to the defrost element and will have open contacts inside it above 50 degrees.
Amana Easy Reach... | Answered on Jul 16, 2013
Sounds like the compressor is in thermal overload. Let it cool down completely and meter the starting amperage on start to run. The compressor could be seized or it's windings could be shorted to ground (checking the resistance between the windings terminals on the compressor while unplugged will determine this.).
Amana Easy Reach... | Answered on Feb 20, 2013
The defrost timer is located in the main control board or on the bottom back side of the fridge. It will be a little black box. But my guess is the control blade which means the board will need to be replaced Good luvk
Amana Easy Reach... | Answered on Sep 08, 2012
check door switches
when you open the dorr does the fan normally stop then on closing start again
could be door switch fault
Amana Easy Reach... | Answered on Aug 15, 2012
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
210 questions posted
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
amana fridge bottom freezer stopped
  • Refrigerators
