20 Most Recent ASUS P5VDC-MX Motherboard Questions & Answers
I have installed windows 7
This board may not support Windows 7 unless you install a video board with 128 MB or more of graphics memory. The onboard video appears to be only 64 MB. The main memory should be at 4GB even though Windows 7 will operate at a minimum of 1 GB(very slowly). I would first run the Microsoft Windows 7 Advisory software to see any compatibility issues. If it was my decision, I would get a new ASUS motherboard certified for Windows 7 with DDR3 memory, a 1GB graphics card, and a 1TB Hard Drive. Upgrading to Windows 7 requires a computer upgrade in most cases.
10/6/2017 12:51:51 PM • ASUS P5VDC-MX... • Answered on Oct 06, 2017
2answers
I am a gamer and p5vdc-mx has only agp slot and i
Hello
I dont think there are any agp to pci ex riser cards.As pci e x16 is part of the motherboard circutry.
There are pci to agp riser cards.If your going to be playing some of the latest games.Most games in the past 3 yrs require a pci x16 vid card.
I suggest geting another motherboard,chipset,and memory.Along with a Pci e x 16 card min 512mb.
8/3/2017 1:35:46 AM • ASUS P5VDC-MX... • Answered on Aug 03, 2017
2answers
ASUS P5VDC-X motherboard wont recognise ram upgrade
this board supports only ddr1
10/31/2014 5:42:12 AM • ASUS P5VDC-MX... • Answered on Oct 31, 2014
2answers
I can not install drivers
*********** board in not compatible to use win 7 drivers were neglected! sorry try vista!!
10/31/2014 5:33:17 AM • ASUS P5VDC-MX... • Answered on Oct 31, 2014
0answers
Sound driver
Be the first to answer 12/31/2013 5:26:02 PM • ASUS P5VDC-MX... • Posted on Dec 31, 2013Be the first to answer
2answers
ASUS p5vdc-MX motherboard won't boot
The light is probably the power light which is ok, but from past experience it sounds like the board is dead for one reason or other. Is it still under warranty? If it is take it back to where you got it, with the purchase docket if you have it and talk to them about what you have tested and ask for a replacement. If it is out of warranty, try ebay or use www.staticice.com.au to search for the same motherboard if you want to rebuild the system without having to reload windows.
11/7/2013 9:36:04 PM • ASUS P5VDC-MX... • Answered on Nov 07, 2013
2answers
I have p5vdc-mx and id like to add a more powerful
The best graphics cards you can run on this board by experience is the Ati sapphire hd 3850 Radeon 512ram, or the next best card I personally had was the geforce xfx 7600gt 256 ddr3 ram, this card was a really good performer.
11/7/2013 9:21:15 PM • ASUS P5VDC-MX... • Answered on Nov 07, 2013
2answers
I have an asus p5vdc motherboard...
Yes, you can put a PCI-Express card into your computer. If you wanted to read over the spec's for that motherboard here they are.
http://usa.asus.com/products.aspx?modelmenu=1&model=814&l1=3&l2=11&l3=242&l4=0
11/7/2013 9:06:27 PM • ASUS P5VDC-MX... • Answered on Nov 07, 2013
Download driver free
unknown divise
10/23/2013 5:03:25 PM • ASUS P5VDC-MX... • Answered on Oct 23, 2013
Driver vga chipset
Ask a question. It isn't difficult, you tell us what the problem is (in as much detail as possible) and then ask us a question about your problem. We don't read minds, so if you don't tell us what you want, we can't help- CAN WE?
10/14/2013 3:39:14 PM • ASUS P5VDC-MX... • Answered on Oct 14, 2013
VGA in moderboard dont work
Install the drivers. Of use your Graphics card output. If the drivers don't help, you can get round this by installing a cheap graphics card instead of replacing the motherboard.
8/27/2013 11:12:51 AM • ASUS P5VDC-MX... • Answered on Aug 27, 2013
I have no sound on p5vdc-mx board
Desktop or Laptop ? and which operating system ? If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings. Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker. volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume. Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable). The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side. You will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity. Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit. Dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for. Tick in either the all software or windows software box IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps Laptop If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings. Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it. If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop. You will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit. dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
12/23/2012 4:16:21 PM • ASUS P5VDC-MX... • Answered on Dec 23, 2012
2answers
No sound from ASUS P5VDC-MX
If everything is OK in Device Manager, check Audio in Sound and Audio Devices under Control Panel. The Sound playback should default to Device Manager device.Plus, make Volume Controls are not muted.Last, simply check with headphones.
12/22/2012 8:25:25 PM • ASUS P5VDC-MX... • Answered on Dec 22, 2012
Starting me hi bios cpu upload error dikha raha hai
When you press start press Del key or continue press del key to go into bios setup. go to last page and reset settings and save then exit It must fix..
12/11/2012 9:05:07 AM • ASUS P5VDC-MX... • Answered on Dec 11, 2012
ASUS P5VDC-MX Motherboard Logo
196 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
vga in moderboard dont work
  • Computers & Internet
