20 Most Recent
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Questions & Answers
Bissell proheat tank-in-tank doesn't seat
I have stuck a connection to the Bissell ProHeat series cover extractor fix guide underneath. This guide resembles my Book of scriptures while I'm dealing with these machines, and is Very useful on making sense of how, and where hoses and parts go, and potential clarifications of issues, and how to fix them.
Check this out:
https://www.olansgz.com/
Removing clear cover to clean Bissell Power Steamer Pro
Post your email address and I'll send you pictures of how it comes off. Make sure the tank is removed and the handle is back, so press on the pedal to release the handle. The reason if feels like it's going to break, it's because there's a seal all around the clear cover to ensure suction and water stay within that area. Pull it straight up, with force.
Connecting a BISSELL AUTO MIX PISTON TO A AUTO MIX KNOB
Take of the housing ,turn it over and you will see the under side of the auto mix dial , Then turn the auto mix dial to rinse only;
On the top of the piston you will see a small slot , this fits into
the out side spiral on the auto mix knob with the dial set to rinse only the top part of the spiail sould point to the courner
Tilt the piston slightly,then hook it on the point of the auto mix knob , when you turn the auto mix dial to heavy traffic the piston should slide down the outer spiral of the auto mix-dial ,
Put the housing back on with the auto mix dial set to heavy traffic, but make sure no tubes are trapped or this will stop the flow of water,
i hope you can under stand what i have wrote ,Goodluck
Leaking soap dispenser
This also happened to us. I just got a new one in the mail - did it over the internet on their website. Haven't tried it yet so hope it is the solution to our problem.
How do I replace the elevator lever arm on my
i have a bissell 7901 and i recently replaced the brush belt. now my problem is the brush while is working the brush is not making contact with the carpet. how can i adjust the brush?
Bissell proheat 2x troubleshooting
Hi, it's Allie from Crucial Vacuum!
There are several things that may cause this to happen in your Bissell ProHeat 2x, like the brush assembly or the belts.
First, make sure the cleaner is reclined, or the brushes will not turn. If your unit is reclined and the brushes still do not run, check if there is anything tangled in your unit's brushes or if the brushes are damaged. Clear the brushes of any hair strands or tangled debris for their optimum performance. We recommend for these brushes to be cleaned and checked monthly and replaced once a year.
Next, unplug your unit and check both of your units belts. It is recommended for belts to be changed every 3 to 6 months, depending on the use of your unit. Belts can be stretched out and loose, causing the brushes not to spin properly.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
