20 Most Recent Comfort-Aire BHD-501 Dehumidifier Questions & Answers
units loose there efficiency over time , five years is a pretty good time for it to work
Comfort-Aire... | Answered on Sep 14, 2015
No, a dehumidifier takes water out of the air where it's placed. If it's very humid in the air, you should have a tank full of water after a few hours.
Comfort-Aire... | Answered on Jan 22, 2015
Are you much of a handyman? Most folks set their dehumidifier on a counter or elevated and run the exhaust tubing right into a sink or toilet. You could collect the water to flush a toilet or water the grass if you are handy. I've never seen anyone connect directly to a drain though.
There's usually a piece or tubing that hangs down into the tank and you need to pull your tank past this when removing it to drain your dehumidifier. Are you lifting from the top or bottom? Try the opposite of what you are doing. Sorry I don't know your model specifically, but often there's an outlet or cap at the bottom of the tank that can have a plastic piece of aquarium type tubing hooked to it. This way if you can elevate the whole dehumidifier, say on a counter, the water can just drain into a sink or if you're a real conserver into a storage tank to use to flush your toilet or water your grass.
No power, no error code equals a dead dehumidifier. Far too costly to repair. I recommend putting those repair bucks towards a replacement dehumidifier. Frigidaire units are highly rated.
Comfort-Aire... | Answered on Jun 14, 2014
Fan turning?
Coil frozen (low on refrigerant) ?
Comfort-Aire... | Answered on Jun 13, 2014
test the voltage at terminal of the fan, if there are according to the plate name of the fan, the FAN is faulty, replace it.
God bless you
Comfort-Aire... | Answered on Oct 02, 2013
Yes you guess right. Despite that the problem might be only one relay you need to replace the whole contol board.
Comfort-Aire... | Answered on Jul 20, 2013
Look on the internet for the make and model they might show you how to do that.
Comfort-Aire... | Answered on Jan 02, 2013
I have a Comfortaire BHD501 dehumidifier. A couple weeks ago I noticed ice building up on top of the unit,so I unplugged it to defrost. I plugged it back in and it worked until I noticed the "CH" "01" code. It would run a few seconds then shut off with that code showing. I took off the front of the unit and noticed rust on some of the metal parts. Then I took the cover off the circuit board for the front read out. I noticed corrosion on some of the solder points. When I looked closer at the plastic cover for the circuit board I noticed a small burn mark. The water from the melting ice must have run behind the cover and shorted out the circuitboard. At this point I don't know if new boards are available.
Comfort-Aire... | Answered on Feb 29, 2012
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Comfort-Aire... | Answered on Sep 07, 2011
What is your humidistat set at? Could you be trying to get to too low a humidity? Try to determine what the humidity is and set the stat just below that. In that way, once it reaches the setpoint, it will cycle off, allowing the coils to warm up.
If that works, lower the setting a bit more & see results.
Write back.
Gary
Comfort-Aire... | Answered on Aug 25, 2011
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Comfort-Aire... | Answered on Aug 13, 2011
heatman101
Comfort-Aire BHD-501 Dehumidifier Logo
69 questions posted
Top Comfort-Aire Dehumidifiers Experts
Bill Long
Michael Youngman
Michael Youngman
Tom Chichester
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Comfort-Aire Dehumidifiers
Most Popular Question
disassemble clean
  • Dehumidifiers
