20 Most Recent
Kenmore 62622 Microwave Oven Questions & Answers
Kenmore microwave removal
the top vent exhaust grill has two screws facing down-remove these. remove plastic vent. inside you will see a solid wire tringle assy. turn and pull this release.
warning if you have granite counters or tile, place plenty of material under it to stop the impact if oven gets away from you
KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one
here. (Enter your model number without any spaces)
We're happy to help and we appreciate your thoughtful rating of our answer.
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Trying to remove built in Kenmore microwave 1994 #89755
You may be able to download the installation instructions from the Sears
parts site.
Just enter your model number there.
A full
Sears/Kenmore model number has 3 digits, a dot, then 8 more digits,
such as ###.########
On the resulting page, look to the right for the blue "View manuals"
button. Click it.
That Sears-related site has many free manuals. While the manuals they
list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions
inside.
If yours is not listed there for free, you would have to order it
through the Sears
parts site.
We're
happy to help you with free advice and we'd appreciate your
Kenmore microwave doesn't heat up
I have the same microwave kenmore 721.62624200. I bought it 5 years ago and the same thing happened. It started humming and it's not heating. All of a sudden this just started happening. Is it worth fixing it?
How do you repair the surface light on microwave
You know how when you turn on a regular light bulb and it burns out with a bright flash? What happens is that when the filament burns out, it breaks and bounces back and hits the other electrical post and basically shorts out causing that bright flash. Sometimes, when the light bulb in the microwave burned out, it shorted out, and caused the circuit-board trace to burn up. (This is not just conjecture; I've seen it.) If that's the case, then you would have to replace the main control circuit board. Unfortunately, a rather expensive repair for no lights. (Although the circuit board trace can usually be repaired by direct-soldering a wire to replace the burned trace. Sears repairmen won't do this, but an independent electronic technician could do it. If you need further help, reach me via phone at
https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Why would my kenmore micro wave model 721.66463500 just go dead, no power
There may be a weakened connection around the main power supply 'Transformer'. Sometimes the connections can overheat but if they are removed and replaced it may again make contact. I've had a similar problem and found parts from similar brands to replace the connecting/wiring parts. I soon realized that I could have removed the extra pieces around the wires without causing any electrical problems. That is the minor repair. The major repair would be to replace one of the main features (large or small) which assist the transformer in power functions. Take your time examining the tiniest parts and pieces.
How do I replace the fuses?
You have to take the cover shell off and locate the fuse.. Its a main power fuse.. will be near where the power cord comes into the microwave.. while you are there look for burnt spots around the board and wires and door switches.. some thing made the fuse blow.. I had this problem a couple of microwaves ago.. it would happen every 3 months.. i bought a pack of fuses and taped them inside the shell so i would not have to go to radio shack everytime i needed one..I never did find what ws blowing the fuzes.. possibly the inverter??
