20 Most Recent
Rowenta Professional DM890 Iron with Auto Shut-off Questions & Answers
My Rowenta iron will not heat up. The yellow light
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
7/14/2020 5:32:40 AM •
Rowenta...
Answered
on Jul 14, 2020
My iron wont heat up and makes a clicking noise
This is a classic thermostat problem and the sound you hear is the thermostat cycling on & off, because it has gone faulty. You need to repair or replace. If you can find an appliance repair center it is not an expensive repair, however always et a "Quote" before proceeding with any repair.
6/15/2010 9:08:46 AM •
Rowenta...
Answered
on Jun 15, 2010
Rowenta iron will heat up and then shut down. Have
Irons use a potentiometer and thermister to control the heat on the element. One of these components is bad and needs replacing. If the iron's still under warranty, get another one. The cost of service would probably be as much as a new iron, but you could call an appliance repair shop to check.
3/12/2010 11:21:36 PM •
Rowenta...
Answered
on Mar 12, 2010
My Rowenta iron seems to be scortching my white
if its a light brown appering on the whites, its just to hot, lower setting. also make sure the plate is clean. the stainless changes colour from heat after a while, this is normal
8/8/2009 4:40:12 PM •
Rowenta...
Answered
on Aug 08, 2009
What is the temperature of the synthetic setting?
I would use some scraps of fabric and transfers to do some trial and error experimenting.
Keep in mind that the iron will not produce steam until the internal temperature is 212 degrees farenheit.
good luck with this.
2/13/2009 1:55:58 PM •
Rowenta...
Answered
on Feb 13, 2009
