20 Most Recent Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Questions & Answers
Sony KDL40EX400 has (2) 2 inch wide vertical color bars about 4 inches from the left side of the screen. Purchased July 2010
If you have tried using different input devices, looked for loose contactsin power outlet, RC Jack, cable and connectors, the TV might need service.
10/8/2022 6:03:20 AM • Sony BRAVIA... • Answered on Oct 08, 2022
3answers
My Bravia Model KDL 46Z4500 (4 months old) turns
Replaced circuit board under warranty.
2/9/2019 4:48:24 PM • Sony BRAVIA... • Answered on Feb 09, 2019
2answers
Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
7/15/2018 2:46:50 PM • Sony BRAVIA... • Answered on Jul 15, 2018
Netflix com activate code 1173r
07107.
4/21/2018 11:27:50 AM • Sony BRAVIA... • Answered on Apr 21, 2018
POWER CUT AND BLANK T.V.
You have a problem with power supply take it to a television engineer
11/17/2017 6:59:39 PM • Sony BRAVIA... • Answered on Nov 17, 2017
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see a light coming from IR eye. If no light emitting, remote needs to be replaced.
10/29/2017 2:57:28 PM • Sony BRAVIA... • Answered on Oct 29, 2017
What causes colored stripes when playing commercial DVDs
Check your cables first to see if they are causing it. Faulty cables can cause all sorts of problems. If that doesn't solve it it could either be that the colour settings are wrong, for example NTSC instead of PAL or vice versa. Sometimes it is something to do with copy protection. In some cases counterfeit discs, or faulty discs. And in some cases a fault on the DVD player.
10/5/2017 4:24:35 PM • Sony BRAVIA... • Answered on Oct 05, 2017
Sony 50" rear projection has horizontal pink/red band issue
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
5/10/2017 1:20:42 PM • Sony BRAVIA... • Answered on May 10, 2017
2answers
How do I get my TV out of standby mode
The main board to your TV should be checked. Contact any service technician. Faults occurred due to lightning is not predictable to any body. In most cases, the main board might need replacement. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
12/12/2016 8:41:13 AM • Sony BRAVIA... • Answered on Dec 12, 2016
How do I check Network settings to connect to an available network in order to use netflix?
If you wish to get some details; check the site linked here. Pull up older posts....... http://electro-medical.blogspot.com/
9/14/2016 9:41:13 AM • Sony BRAVIA... • Answered on Sep 14, 2016
HDMI inputs knocked out by power surge from lightning. RCA jacks, sound and picture still work, just not high-def. Is this a simple fix or am I without HDMI on this Sony Bravida? Thanks, Mike
You will have to replace board the hdmi's are on. Take back cover off. Should be 4-8 screws holding board. Disconnect ribbons etc...should be a # on board itself. Amazon or ebay
8/30/2016 2:17:27 AM • Sony BRAVIA... • Answered on Aug 30, 2016
Approximately 2/3 of the screen is dark
Hi there...it is sounding like a backlight is going/has gone out...these can be proffesionally replacedat a repair shop...To self diagnose if it is the backlight take a flashlight and, with tv on and while on a tv channel and carefully form different angles look into the 'dark' part of the tv screen...if the/a backlight on a lcd tv/monitor goes out(even laptop screens) then u can still see a faint image with a flashlight(or without one with a good eye)....If you still see the (tv channel) image, then it is most likely a bad backlight......
I hope this helped you some, if it did(or not) please rate!...Thank you
7/12/2016 9:22:00 PM • Sony BRAVIA... • Answered on Jul 12, 2016
Bulb takes long time to get bright but not bright enough
Check the voltage to its inverter board. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
5/27/2016 3:02:13 AM • Sony BRAVIA... • Answered on May 27, 2016
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
5/20/2016 9:01:05 AM • Sony BRAVIA... • Answered on May 20, 2016
Press remote red shows then green then back to red
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
4/2/2016 12:46:28 PM • Sony BRAVIA... • Answered on Apr 02, 2016
No picture, no sound.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
3/29/2016 4:41:51 PM • Sony BRAVIA... • Answered on Mar 29, 2016
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
723 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony bravia kdl 40d3000 no longer
  • Televison & Video
