20 Most Recent
Dell Inspiron 6000 Notebook Questions & Answers
Unable to copy dvd's
Most dell machines do no come with dvd rewriting as standard. They only come with cd rewriting capability. Unless you specifically requested it as an add on to the spec it probably just has the ability to pay dvd's.
Most internet cafe's will have a machine with a dvd rewriter if you really need to copy a dvd
Val
My computer crashed about 7 months ago. I got it
when u put the disc in does it automaticly open windows media player with the movie? if so after the dvd is in close media player ,go to "my computer" then go to the drive your disc is in and right click chose explore or open in new window on the video files u see right click one of them and choose "open with.." then click browse and navigate to your c:/drive program files and look for power dvd u will need to select the powerdvd.exe also make sure the box is ticked that says always use this program to open this kind of file ......make sure u have the rite codec's installed as well this link is for windows XP video codecs http://www.free-codecs.com/download/XP_Codec_Pack.htm this one is for windows vista http://www.free-codecs.com/download/vista_codec_package.htm and this 1 is for windows 7 http://shark007.net/win7codecs.html
Dell Inspiron 6000 - trying to reload, but not
You might need to go into the computer's BIOS and see if it's set to boot from a bootable CD or USB device. If it's set to only boot from the hard drive, it won't even look at other drives. Different computers use different ways to access the BIOS: you might try pressing the F12 key when the boot logo appears. Check your owner's documentation - it should tell you the procedure for your computer.
Where can I download an owner's manual?
www.
dell.com/support/home/us/en/19/.../
inspiron-
6000/
manuals
DellManuals & documentation for your Inspiron 6000. Last Revised: 7/8/2013. Manuals.Inspiron 6000 Owner's Manual PDF (1724 KB). More Languages. Deutsch ...
www.manualslib.com > Brands > Dell Manuals > Laptop > 6000
View and Download Dell 6000 owner's manual online. ... Dell owner's manual notebook pc inspiron 6400, e1505 (186 pages) ... NOTE: Corporate, government, and education customers can also use the customized Dell Premier Support ...
HP compaq 8710w tries to power up but flashing yellow light and shuts down
Is it plugged in? If so then most likely it is not taking a charge. This could mean your charger has gone bad, the cord leading to it is bad, the cord going to the computer is bad (search for breaks or chewing if you have animals) or the port where you plug it into the computer has suffered damage. This last one is internal as the actual port has come loose where it is attached/ soldered onto the motherboard. You would have to bring it to a qualified repair technician for this. You can also find some online.
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Dell Inspiron 6000 not picking up wireless signal
There are lots of problems of using wireless LANs in metal buildings, especially if you are trying to go outside the building and into another building. What I have had to do where I work is put an external antenna on the wireless router and use that to transmit the signal beyond the metal shell of the building.
If that still does not yeild satisfactory results, you can set up another wireless router in the "home" location with an external antenna to act as a recieving point for the other router in the office ... essentially this is setting up a site to site network. With both routers working together you should resolve the wireless drop out issue.
Bestbuy also sells a Wireless Booster, this works the same way as I explained with using two routers however if you go that route be sure you have the option to either add an antenna or you can place it near a window (glass cuts down on your signal than steel).
If this fails look at replacing the wireless card; this setup will still provide benefical even if you need to replace the card as it will provide stronger signals in stormy weather as well.
