20 Most Recent
Hamilton Beach 50754 WaveStation 10 Speed Blender Questions & Answers
The base is broken
check with abtec.com. They seem to have parts for the Hamilton Beach model 50754 blender but I seem to remember the blade and base come as one unit.
I am looking for replcement
the only place I have been able to find that has any parts for this model blender is abtec.com. Parts are expensive tho.
Blender seems to run right
Disassemble the base from the jar, and check the placement of the gasket. Reassembly, with the jar upside down is gasket, blades, then base. While disassembled, rotate the blades by hand just to make sure that they aren't in a bind. Replace if defective.
--W/D--
Need to know how to
First you set the plastic base on.Then you put the grinder blades on.Then put the gasket on top of that.Then screw in the glass container.All blenders are set up that way.I am including a link for your blender,just in case you do not have one or lost yours.Just click on your number and a new screen comes up.You do not have to sign up for anything,just enter the 5 digit code.This will not result in all kinds of pop up junk either.If you do not have Adobe,simply do what it asks you when prompted.It is a free safe download and is commonly used.Greg
http://www.retrevo.com/samples/Hamilton-Beach-Blender-manuals.html
I am trying to figure out the wiring for the multi
maybe check the thermal fuse inside non resettable need to purchase one , check with test meter first. unplug the machine. then test wiring on continuity setting. then check for voltage flow to switch
Hamilton Beach Blender Gasket
Possibly the gasket while it lasts on the cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-WAVE-ACTION-CUTTER-BLADES-REPLACEMENT-PART-/161615007502?pt=LH_DefaultDomain_0&hash=item25a1014f0e For an unused replacement, try typing in your model number at HB's parts site, located by clicking
here . Many www sites like abtecparts.com and goodmans.net could help you. Besides matching description, I would match the pictures of what you are going for against what you've got as much as possible. Good luck!
Hamilton beach 54205 jar
Possibly on the cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-GLASS-PITCHER-5-CUP-40oz-JAR-REPLACEMENT-PART-/161614412690?pt=LH_DefaultDomain_0&hash=item25a0f83b92. For an unused replacement try typing in your model number at HB's parts wesite located by clicking
here . Check out the many www sites like abtecparts.com and goodmans.net. Besides matching description, I would match the pictures of what you are going for against what you've got as much as possible. Good luck!
