20 Most Recent
Acer Aspire 3610 Notebook Questions & Answers
How to remove password
After you login to the account,Goto Controlpanel>>User accounts>>Click on the Username
-Click on Remove Password
-It will prompt you to enter the current password
-Enter the current password and then restart the system to find that the issue is resolved
How do i operate my
I can't verify this, but it's worth a shot:
Go into Acer Arcade or Acer Arcade Deluxe OR go into Windows MediaCenter and then select Acer Arcade. Once in Acer Arcade there should bea program called DV Wizard. Once in DV Wizard select Acer Crystal EyeWebcam and the rest is obvious. Once you are done and click stoprecording, the video that you recorded will be in your Videos folder.
Source
Need help to get cheap laptop
Your best bet is ebay or craigs list. there are tons of cheap laptops out there. also, check out your local computer swap meets.
Cannot acess my internet security provder website
try first to remove the anti-virus you are using and restart computer....scan computer with anti-malware bytes ...after that..you install again the anti-virus...and try to activate trhough internet.
Acer 7530 ffdg65
hello,
Go to acer.com select your model and download the driver.
I can't get my Acer Aspire 5735 crystal eye to record live action
I believe your best bet is to use Windows Movie Maker to record your videos.
http://www.worldstart.com/tips/tips.php/2928
The acer's built in software is designed to only do snapshots. There are tons of free software available, but Movie Maker is the easiest to begin with. Any "video capture" software will work. Have fun; don't forget to rate this.
Crystal eye
use handy recovery to recover the images i am giving the link for the trail version select the drive were do u expect the image to be deleted then analyse it and recover.. and i dont think crystal eye can recover deleted images only handy recovery can this is the link....
http://www.handyrecovery.com/download.shtml
Volume control
Click start control panel on the left select Hardware and Sound
then select manage audio devices then recording you should see a Microphone
right click select enable Windows 7
Click start control panel on the left select hardware and sound
right click select configure speech
recognition then
You will see earphones with a speaker among a list set up a
microphone headset with Microphone then
next and next again you should see your
earphones with microphone being configured
sounds and audio devices select advanced there might be a tick in the mute box
untick it or select audio from the microphone drop down list
Make sure you have the
right one selected and in the volume box make sure the microphone box has a
tick in it or
select the voice tab
Make sure that you have the
right media selected also
select volume make sure the
box for microphone has a tick in it
Acer laptops run on the Windows operating system.
They also have built-in speakers that have a menu to change
the settings.
All laptop speakers have a driver that tells the speaker how
to function.
If the driver gets damaged or deleted, the speakers are
rendered unusable.
Acer speaker problems usually have a driver issue that can
be solved by the user.
Go to "Start," "Control Panel," "System and Security
(or System and Maintenance)," "System," then "Device Manager."
Type in the Administrator password, if you are prompted to
do so.
Click on "Sound, Video and Game Controllers."
Right-click the name of your Acer speakers and select
"Update Driver Software."
Click on "Search Automatically for Updated Driver Software"
and allow the computer to download any updates.
Reboot your Acer laptop.
Raise Speaker Sound Levels
Click on the "speaker" icon located in the lower
right corner of your desktop.
Raise the volume bar all the way up to increase the sound.
Select "Mixer" to raise the other
volume bars all the way up.Windows 7 right click on the speaker icon in the
taskbar select either playback or recording devices you should see your
microphone listed under the recording tab right click on it select
properties at the bottom
select use this device enable
