It doesn't cool
- Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
- Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
- Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
- Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
- Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective.
Refrigerator Repair Help Troubleshooting and Parts
