20 Most Recent
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Questions & Answers
Remove climate keeper air tower ge arctica dual evaporator refrigerator
The Climate Keeper in our 2006 GE Monogram refrigerator lifts up, pulls away a little after the screws are clear AND it has two pieces of plastic on the bottom sides that need to be pushed toward the center to get it out. Lift it up and clear the top screws, then put your hand behind the climate keeper at the bottom and find those, then push one in, then the other. Took us forever to figure this out. Photo attached of the inside of the climate keeper at the bottom. Best of luck!
The site was taking too long to upload a photo. ugh.
Ge refrigerator won't hold set temp-gets too cold
Probably the motherboard - the weakest link in the system. They're made in China using the cheapest components the chinese can find. Expect it to fail early and often.
Same is true of every other so-called "smart" appliance on the market.
Samsung twin door fridge water leaking onto floor
I have a Samsung side by side - model RS253BAWW.
Water was leaking onto floor from main refrigerator, not freezer. It was determined to be a blocked defrost drain.
The
repair technician removed the trays and food from fridge, remove the
screws from the panel at back, disconnected everything and remove panel.
The stainless tray at bottom of fridge as well as panel itself had solid ice blockage.
He
placed panel in sink and used something similar to a blow dryer with
narrow hose on it to defrost both the panel and drain in fridge. Took
him maybe 15 minutes and charged $99 total for the visit.
In future I
will do this myself now that I know how but thought it may be useful
information to others who are having similar problems.
My Samsung model RS267LASH has a small leak coming
I believe it is a condensate leak. every time your refrigerator defrost the water follows a tube to a pan below the refrigerator. Im going to send you the manual and a link to click on to see what will be involved to help you resolve this, Sea Breeze
Is this referred to as
On refrigerators the compressor,condeser coil,the evepartor coil& and the tubing connecting those components plus the refrigerant is refered toas the sealed(closed) system
GENE
My model PFS22MIWABB freezer is
Had the same problem recently- it's the mainboard not functioning properly. Part # WR55X10942 - just had installed by GE repairman ($290.00 later), and it's as simple as removing 3 screws on the back and swapping out the board - for the future I'll gladly do myself. Part itself can go for around $100.00 online.
My problem is the refrigerator sounds like it's
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
