20 Most Recent
Kenwood KDC-MP4032 CD Player Questions & Answers
No power on my Kenwood kdc mp 4032
I would use a test light or multimeter and see if you have system voltage at the back of the deck on the power wires. This will tell you whether the problem is with the Kenwood or the wiring and components coming to it. Remember the car has a radio fuse too
6/5/2016 4:23:35 PM •
Kenwood...
Answered
on Jun 05, 2016
Wiring diagram
Yellow..12..memory
red...12v..ignition
orange...illumination
black..chassis ground
blue..remote..antenna
white..front left+
wht/blk..front left-
Green.. rear left+
Grn/blk..rear left-
Gray..front right+
Gray/blk..front right -
Violet..purple..rear right+
Violet..purple..rear right-
These are generally standard colors..hope this helps
4/14/2014 7:06:04 PM •
Kenwood...
Answered
on Apr 14, 2014
It just started flashing protect
"PROTECT" :- The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
Reset is a tiny little hole hole to the right of preset buttons along bottom of unit, Insert paperclip to reset to factory settings?
Good luck with it
7/20/2012 1:25:10 AM •
Kenwood...
Answered
on Jul 20, 2012
KDC-MP4032 head unit wont turn on
hi, seeing that your kenwood showed up "protect" you may have an audio circuit/amplifier fault within the unit. try resetting the unit to see if unit comes "on" again. if the unit comes on and protect flashes again, then you definitely have an internal audio circuit fault. if not then check all power connections(yellow and red wire voltages, as well as ground connection), as well as the condition of the face pins!
6/2/2012 11:09:43 PM •
Kenwood...
Answered
on Jun 02, 2012
I need the code in
One of the following procedures to clear the security code should work:
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that "..." disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing your "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. If your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key
* Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
push button "track up" for 3 seconds
The security is canceled and the set enters the TUNER mode.
9/18/2011 5:52:48 PM •
Kenwood...
Answered
on Sep 18, 2011
