20 Most Recent
Fedders A&B Chassis A1A07W2B Air Conditioner Questions & Answers
My air conditioner doesn't blow out any air.
If this is a central air unit & you\'re talking about the fan on the outide of the house the problem may be that you are only getting 110 volts to the system side of the contactor. If you have the tools & know how you can check this yourself. If not, time to call a repairman.
Light gray smoke
The "take" guy is right, and I know from first hand experience. I knicked the refrigerant line trying to put extra drain holes in the unit and I saw all the gray odorless gas fill my daughter's room. It stopped shortly. My cousin who fixes AC units for a living told me, there is no way to fix it, and U have to buy a new one.
THE AC IN THE MOBLIE HOME MY SON JUST MOVED INTO
I might suggest that the ducting under your mobile home is disconnected or that the air filter on the furnace hasnt been in place for a long time and the cooling coil is partially blocked with dirt. The Coleman furnace sits on the cooling coil and it may need to be inspected through a front panel to verify that its dirty before going through the trouble necessary to disconnect the drain at the bottom front and carefully sliding the coil out a little. I strongly advise you get someone qualified to help you. Hope this helps.
My central air conditioner wont
Check the Filter 1st, that might lead you to find either a frozen coil.If neither of those thingsare the problem, check to make sure the blower is operating.
When a/c is on, it makes a humming rattling
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I have a fedders a/c heating unit that I have been
when you turn on unit can you hear the compressor kick on or is it just fan . I you can hear compressor kick on then most likely you do need a boost of freon but if you can just hear fan without compressor its either freon or compressor is bad or the little secret mechanics dont like to tell??? No joking check the wiring going to compressor pull off the cover where connections are and inside there is a little round surge relay that goes bad often.Its a 10.00 part at any local a/c supply company or you can just bypass that relay but make sure if bypassed that you have the run and start wire on the right peg the wiring diagram will show that if nothing else call a appliance company to come out and total repair bill if it is that relay should be 80.00 hope this helps
Can you please tell me how to fill the ferroli
you will find two black handle iso valves by the pressure gauge at the base of boiler turn both valves so that the handles are inline with pipe work and this will fill the system only fill to 1 to 1.5 bar standing pressure
FEDDER'S PORTABLE UNIT SAYS STOP. WONT RUN
Disconnect power to the unit and reconnect. If "stop" is still on the display you will probably need a qualified technician to trouble shoot. The best mode is the snowflake (cooling). The rain drop is dehumidification which can cause condesation on unit.
