20 Most Recent Kenmore Elite HE4 Electric Dryer Questions & Answers
3answers
Kenmore HE4t Dryer - no heat
The usual suspect for a Kenmore HE that runs, but doesn't heat is a thermal cut-out or the thermal fuse. Although they are a bit more resilient, in some cases the heating element itself could be bad. The way to check: 1. UNPLUG THE DRYER, FIRST. 2. Remove the bottom kick plate on the front of the dryer. 3. Remove the blower fan cover directly under the lint screen. There should be a couple of 1/4" screws holding it on. 4. Directly behind the blower fan cover on top of the blower fan housing are two components. One is the operating thermostat, and the white one is a thermal fuse. The fuse is a one-shot fuse that must be replaced if it is bad. 5. To the right is the heating element housing. There are two additional components mounted on the side of the element housing. The component furthest to the back is the thermal fuse. The one one closest to you is the hi-limit thermostat. 6. Check the continuity of thermal fuse and the thermal cut-out. They both should read a short. Additionally, check the resistance of the the heating element. The element should read something low (less than 20 ohms). 7. If the thermal fuse reads open, replace it. If the thermal cut-out is bad, replace the hi-limit thermostat with it. They are usually sold as a set. If the heating element is bad, you will need to disconnect all electrical leads and remove one 1/4" screw holding the element housing to the bottom casing. Pull the entire element housing from the dryer. Depending on model, sometimes the element slide out of the housing, sometimes you will need to remove a few screws to open it up. I hope this helps you.
4/15/2023 9:41:05 PM • Kenmore Elite... • Answered on Apr 15, 2023
My electric dryer takes a long time--3 hours or more to dry a load of wet towels
Start with cleaning the vents
4/9/2023 1:31:59 AM • Kenmore Elite... • Answered on Apr 09, 2023
3answers
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
1/12/2023 7:56:11 AM • Kenmore Elite... • Answered on Jan 12, 2023
2answers
Maytag dryer epicz says "controls
controls locked
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
To enable the Control Locked feature:
Press and hold AUTO DRY LEVEL for 3 seconds. Control Locked
glows and a single beep tone is heard. To unlock, press and hold
AUTO DRY LEVEL for 3 seconds. The indicator light turns off.
12/24/2021 3:52:53 PM • Kenmore Elite... • Answered on Dec 24, 2021
Dryer will not stay running
Most customer manuels have a code listing in the back? Have you checked to see what E1 is? It sounds like its not sensing properly. the sensor works off the vent...so the most common problem is the vent or venting. Please check and advise
2/14/2019 11:36:51 PM • Kenmore Elite... • Answered on Feb 14, 2019
Black scuff marks inside dryer, all over
Mr. Clean Magic Eraser will do the trick perfectly.
1/31/2019 2:06:59 PM • Kenmore Elite... • Answered on Jan 31, 2019
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
12/9/2018 5:03:29 PM • Kenmore Elite... • Answered on Dec 09, 2018
3answers
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
10/18/2018 5:53:01 AM • Kenmore Elite... • Answered on Oct 18, 2018
I have a kenmore elite front load washer model
there is a clean out to the left or the pump.it should be in the middle front when you remove the bottom panel.[hint] have a shop vac on with the hose next to the clean out so you don't get water every where.if you do not have a wet/dry vac and it is on a pedistal open the drawer and put a small trash can in it.hpoe this helps.
2/11/2018 6:46:45 AM • Kenmore Elite... • Answered on Feb 11, 2018
Burning smell
Sounds like your drier is over loaded. Belt slipping due to : to much weight in drier. The drier motor is an adjustable. Belt test: If you can twist belt more than a half a turn it is to lose. Replace belt.
2/10/2018 3:14:34 PM • Kenmore Elite... • Answered on Feb 10, 2018
2answers
Whirlpool made for Sears (Kenmore)
send the model number,open the door look around the opening where you put the clothes in you should see a tag there.if you unplugged it and it worked then it's not any of the t-stats or door switch most likely a board issue or something to do with the cord from moving it,when you unplug it and plug it back in your resetting the board so this is what it sounds like but can't tell if you even have a board without model number.
1/14/2018 6:33:35 PM • Kenmore Elite... • Answered on Jan 14, 2018
Dryer stops after a short time, cloths not dry yet
what's the brand name and model number?
1/6/2018 4:42:54 PM • Kenmore Elite... • Answered on Jan 06, 2018
Model # 11061082000 electric dryer....elite kenmore
you can't get any parts for this dryer the computer board is no longer available,must be old technology replace it.
1/2/2018 11:49:53 PM • Kenmore Elite... • Answered on Jan 02, 2018
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
11/3/2017 10:36:44 PM • Kenmore Elite... • Answered on Nov 03, 2017
My ht5 dryer will start and run it gets hot and
Most likely a control issue. Will it come right back on after shutting down or does it need to sit a while?
11/3/2017 12:01:41 PM • Kenmore Elite... • Answered on Nov 03, 2017
0answers
2answers
My Kenmore Elite bottom freezer
Contact the mfr. and have them send an authorized technician to repair your refr. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
10/25/2017 7:47:19 PM • Kenmore Elite... • Answered on Oct 25, 2017
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
10/12/2017 8:49:34 AM • Kenmore Elite... • Answered on Oct 12, 2017
Kenmore Elite HE4 Electric Dryer Logo
1,774 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
dryer turns but drum will not spin
  • Dryers
