20 Most Recent
Bosch Axxis WTA4400 Dryers Questions & Answers
Bosh axxis filter. how do i clean it? soap and
First of all the item I referred to in my question is actually a heat exchanger located below the dryer drum.
The maintenance man in the condo said remove it and clean it with soap and water. I did have a garden hose with a sprayer so I used the bath tube to give it a good cleaning.
It now looks clean and I cleaned the housing where this part is located with vaccuum and wet cleaning.
jtoolan 6-12-09 7:45 AM
My bosch dryer is not
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101
How to replace selector switch (timer)for bosch
Open the top cover holding with three screws. Open the console by opening three screws.Than open timer holding plate(four screws).Timer is attached with two screws with plate.Take the nob out and reverse the procedure.
Thanks.
Bosch classixx condenser drier
The problem is with the lower water tank float switch, it is stuck. Take off the right hand side panel (as you are facing the machine) at the bottom you will see a spring mechanism for the belt tension. Beside this there are 2 electrical connectors. Take them off and spray with wd40 or similar. Whilst off give the plastic box they fit 2 a light tap with a hammer to free the float switch. Reconnect and try. If this fails you can over-ride by leaving the left hand of the two plugs off. This will get your machine working but you will not have an indication as to when the water container needs emptying so you will need to remember.
Dryer runs but no heat and clothes stay wet and
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
Dryer heating then tumbler stops after 10min but
IS THE DRYER A SENSOR DRYER IF SO TRY PLACING A JUG OF HOT WATER INTO THE DRYER, BUT DO NOT EMPTY THE WATER IN THE DRYER, JUST LET THE STEAM OFF THE WATER OPEN THE SENSOR HOOVER DYERS HAVE THIS PROBLEM TO
This is a Bosch electric
are you sure it is the element, and yes repairing it is a whole lot cheaper:
http://shop.ebay.com/i.html?_nkw=heating+element+dryer+bosch&_sacat=0&_odkw=heating+element+dryer&_osacat=0&_trksid=p3286.c0.m270.l1313
this should assist you:
http://www.espares.co.uk/advice/tumble-dryers/a/9/1344/how-to-replace-the-heating-element-assembly-o.html
No heat
the first thing to check is that you have 220VAC at the plug. If one leg of the circuit drops out you can have this symptom.
Dryer runs, but no heat
take the back panel off and look at the heating element can there is a thermal fuse that has a small reset button on it. push this in if that does not work then you need to check all the thermal fuse as well as the heating element for continuity if there is any of the above mentioned items that do not have continuity then replace the one that does not have anything
