20 Most Recent
Panasonic Workio DP-4530 Copier Questions & Answers
E01-22
check the polygon motor 7& sc pcb connector
Pls tell me the life time of the developer powder
I have not come across any expiry date of toner/ developer and if it is stored properly in a cool dry place, away from sunlight an excessive heat, it works just fine.
Re-filling the toner is always cheaper and costs around 1/4th of the new toner price. So, check for the price of new toner and compare. Genuine toner is always better in terms quality and yield. However, refill can work too.
I have refilled/ refurbished toners myself and had no issues. Properly re-filled/ refurbished cartridge would NOT cause any damage to the printer. So, you may get your toner refilled by some good professional and it would work fine.
As for Panasonic Workio DP-4530 and similar copiers, the toner comes in a bottle (which is only a container filled with toner powder) and the toner powder is pulled by the toner supply unit of the copier. I am using HP 9065MFP and refilling caused no issues. I usually refill it after proper servicing and use best available powder and it works absolutely fine.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Its me again,after the user changed a new toner
After a few copies, the toner supply unit pulls more toner, which results in dark copies. To fix this, you have to reduce the contrast (to minimum). Also, make sure that there is no excess toner within the toner supply unit.
CreativeTECH
I am getting this error
CHECK THE CHARGING CORONA.IT MAY BE DIRTY DUE TO TONER OR DEVELOPER DUMPING.CLEAN IT WITH SPIRIT OR ALCOHOL
Panasonic 4530. getting light copy,
Hi
I believe the developer is too old and needs replacement. Also, check the drum unit is it old coz the life of this machine part had limit number of copies. Try to replace them both.
But I have trick solution for old drum unit. Just adjust the contrast of the printing quality to the maximum and surely all your prints will be darker. I have done this before that I adjust the contrast to the max and it prints and make copies more darker.
I hope it helps you as well.
E07-20 Machine Error
Hello sir; The error code you display , it's means " finisher transport motor, 2nd feed motor , shutter senser , shutter switch or safety switch" you have check all those item, most likely is switch .
