20 Most Recent Samsung Pn50a450 Pn50a450p1dxza 50" 720p Hd Plasma For Repair Or Parts Questions & Answers
Samsung plasma black line fix
Sustain board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to Plasma screen are given with illustrations.
8/6/2014 2:06:12 PM • Samsung Pn50a450... • Answered on Aug 06, 2014
There are thin, colored vertical lines on my plasma tv.
bad pdp panel
3/14/2014 2:20:25 AM • Samsung Pn50a450... • Answered on Mar 14, 2014
Samsung PN50a450p1dxza has a 1" thick pink/red vertical line. What can I do?
I would suspect a defective lower scan board
5/22/2013 2:34:06 PM • Samsung Pn50a450... • Answered on May 22, 2013
0answers
1 vertical black line on samsung plasma tv on left side (model # pn50a450p1dxza)
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
8/20/2012 10:34:35 AM • Samsung Pn50a450... • Answered on Aug 20, 2012
What size screws does a SAMSUNG TV PN 51E530 require for a stand mount
I just looked up the manual online and it clearly shows that the screw size is M4 x L12 metric screws
6/2/2022 7:28:11 PM • Samsung PN... • Answered on Jun 02, 2022
I have a Samsung PN50B530S3F plasma TV 2009. It has a black horizontal lines problem.
check the display strip. un plug it and fix it
5/14/2019 12:54:56 PM • Samsung PN... • Answered on May 14, 2019
Samsung plasma TV PN63A650 will not turn on, just makes continuous clicking.
the capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
1/5/2017 7:30:41 PM • Samsung PN... • Answered on Jan 05, 2017
Samsung 60 inch plasma not turning on. Unplug HDMI and turns on. Let it warm up (15min) then one HDI (720) works. Replaced caps but no change.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
6/30/2016 2:20:35 AM • Samsung PN... • Answered on Jun 30, 2016
2answers
Problems with video on samsung pn58c680g5f
www.samsung.com/us/support
2/1/2015 12:46:43 AM • Samsung PN... • Answered on Feb 01, 2015
My Samsung flat panael shuts itself off continuously
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
9/13/2014 11:12:41 AM • Samsung PN... • Answered on Sep 13, 2014
Samsung Plasma..clicking pn50a400c2dxza
Have you checked the sustain board/s. If you wish to get some details about how to check a plasma TV, visit the site linked here. It has details with illustrations. The shown is for an LG brand plasma, but all the plasma TVs will have same configuration and checking procedure, irrespective of its brand and screen size. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
8/27/2014 3:21:31 PM • Samsung PN... • Answered on Aug 27, 2014
2 year old plasma on 5 minutes no pic, but sound
yes take it to a tv tech would be your best bet. regards shaun
4/21/2014 4:30:08 AM • Samsung PN... • Answered on Apr 21, 2014
0answers
Samsung Pn50a450 Pn50a450p1dxza 50" 720p Hd Plasma For Repair Or Parts Logo
11 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
PN Samsung
  • PN Samsung
Most Popular Question
samsung plasma black line fix
  • Televison & Video
