20 Most Recent
Epson ACULASER CX11NF All-In-One Printer Questions & Answers
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim
report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
Scan document into text
Scanned documents are image documents and they need to be converted using an OCR program. The Optical Character Recognition program converts scanned image documents into a text file which you can open with a Word program and edit.
You need OCR programs such as -
OmniPage 17
ReadSoft
GOCR (freeware)
Tesseract OCR (freeware)
Microsoft Office Document Imaging (included in MicroSoft office Tools)
I have a message on
Hi travlynn2,
- The ADF unit is the grey paper tray located on the top of the scanner unit. Check the following points if it does not feed paper, or you receive an "ADF jam" error message:
- Check the position of the ADF document guide:
- Lift up the ADF unit. Locate the document guide on the underside, as shown here:
- The document guide should be tucked in behind the grey plastic casing, but a paper jam can push it out of position. Figure 8 below shows the correct (1) and incorrect (2) positions:
- If your document guide looks like example (2) on the right, lift it out on the right-hand side. Tuck it in behind the grey section, so that it matches the example on the left (1).
- Close the scanner unit.
- If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
- Test the printer by scanning or faxing via the ADF unit.
- Check the ADF edge guides:
- The adjustable paper tray edge guides must be set to the correct paper size for the paper you are loading. Otherwise, the paper may skew, misfeed and/or jam.
- Slide the edge guides to enclose the loaded paper (in the direction of the yellow arrows below), without causing it to bunch or crease. The paper should be aligned with the relevant paper size marker: Figure 9. The ADF edge guides.
- Check the ADF unit feed rollers:
- Open the cover of the ADF by pulling up the grey lip, as shown below:
- Check thoroughly for fragments of paper and foreign objects. Take care not to tear any jammed paper when you remove it.
- Use the green gear (circled in yellow below) to turn the paper feed rollers and feed through jammed paper:
- Paper dust or foreign material on the rollers may cause paper to misfeed. Clean these parts with a damp, well-wrung cloth:
- The upper paper pickup rollers (circled in red, above top left). You can turn these by hand.
- The lower paper pickup rollers. These will rotate as you turn the green gear (circled in yellow above). See the inset for a close-up of the lower rollers.
- When complete, close all the covers.
- Check that the ADF unit sensors are not obstructed.
- Open the cover of the ADF unit.
- Look at Figure 12 below. Check the position of the black plastic parts (the actuators) circled in red.
- If the black plastic actuators do not stick out from the ADF cover, they may have been pushed out of position by a paper misfeed and be obscuring the ADF sensors. Tap the back of the ADF unit firmly to release the actuators.
- When complete, close all the covers. Check and test the printer as explained in Step 6.d.vi.
Hope this helps.Thank you for using FixYa.
WHAT CAN I DO WHEN WORN YK DEV UNIT MESSAGE APPEARS
People think about it. Contact the manufacturer of your specific model for the error codes or order an manual from them. Most people seem to soft to actually do the research. If a company has fallen from grace I can see the extra outreach but look it up. I can.
Vertical smudges across entire page getting worse with every print
If it is a laser printer, it almost sounds like either a fuser issue or a voltage issue. Is the smudge properly bonded to the page or does it smear off. If it is not bonded then the fuser is the problem. If it is fused then likely you either have a bad photoconductor or a power issue. Make sure that the printer is plugged into the wall and not on the same circuit as high draw items like heaters or AC units.
