20 Most Recent Konica Minolta C6500 C5500 C6501 C6000 C7000 Developer Set C/m/y/k Dv610 Questions & Answers
2answers
C6501 error c2454
black developing motor error Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
9/6/2019 6:08:28 PM • Konica Minolta... • Answered on Sep 06, 2019
How to do a sensor test on a bizhub c6501
Sir/Mam, Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/25/2018 9:25:27 PM • Konica Minolta... • Answered on Mar 25, 2018
Add toner k message
add black toner than Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 7:47:21 PM • Konica Minolta... • Answered on Mar 10, 2018
C-6402 error code
again no such code in the service manual Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/4/2018 8:23:57 PM • Konica Minolta... • Answered on Mar 04, 2018
C-6402 error code in C6000
3/4/2018 8:22:58 PM • Konica Minolta... • Answered on Mar 04, 2018
I have a konica bizhub press c7000, we tried to
Rated my who?????? try this site Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/25/2018 12:22:05 AM • Konica Minolta... • Answered on Feb 25, 2018
C 3201 code
no such code for that machine Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/9/2016 10:11:30 PM • Konica Minolta... • Answered on Jul 09, 2016
Error code c-2454
check the black developer motor and developer unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/6/2016 12:13:44 AM • Konica Minolta... • Answered on Jul 06, 2016
Bizhub error code C0314
When the paper feed assist fan/ Rr21 (FM6) was ON, FM6 abnormality detection signal was continuously detected for the specified time. PF drive board (PFDB) Paper feed assist fan/Rr21 (FM6) Rear guide of tray number 2 has a fan that is bad replace Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/5/2016 12:53:09 AM • Konica Minolta... • Answered on Jul 05, 2016
Changeing gears of a developer housing on a 6500 konica
have tech come out or search web site for service manual Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/24/2016 9:47:59 PM • Konica Minolta... • Answered on Jun 24, 2016
Error code 3101
Generally, C-3101 refers to a motor problem. Possibly the drive board. No clues on a simple fix. See if is still under warranty.
5/6/2016 9:39:21 PM • Konica Minolta... • Answered on May 06, 2016
Tray won't close after clearing paper jam.
Yes have a tech come out and repair it that is very expensive machine mite want a professional working on it. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/16/2016 11:59:59 PM • Konica Minolta... • Answered on Mar 16, 2016
Image repeat in cyon colour
check the fusing unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/24/2016 4:03:35 AM • Konica Minolta... • Answered on Jan 24, 2016
Error code C4521
This going to take a while, open both front doors do not pull out the lower section your, going to pull out the upper middle section.(One screw way upper left just below the control pane loosen will not come out make sure you screw that back in when done VERY important can cause codes) then from the right side (WHAT EVER YOU DO NOT LEAN / HOLD ANY ONE OF THOSE FOUR SHAFTS!!!!!!!!!!!!!!! THAT WILL CAUSE MAJOR TROUBLE! Now reach in and you will see a small assy. which is across from the transfer belt on the other side of the unit you just pulled out. On the assy. are three sensors each covered by a metal cover with a dry rag ensure no static electric can destroy the sensors. clean all three, be careful each has a small spring do not let them fall inside the machine. If you want to or have to remove that assy. there are two screws and once connector all the way in the back (DO NOT LEAN ON THOSE SHAFTS!!!!!!!!!!!) don't let the screws drop ! Once done remove the transfer belt, and clean the transfer belt cleaning blade system, then run gamma, and color checks in 36 Mode. GOT IT! Better have a tech come out. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/18/2016 9:12:35 PM • Konica Minolta... • Answered on Jan 18, 2016
Stays in waiting mode
recommend you have tech come out mite require replacing developer in all 4 units Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/16/2016 3:19:58 AM • Konica Minolta... • Answered on Jan 16, 2016
C7000 static
have a tech come out and look at it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/15/2016 10:33:32 AM • Konica Minolta... • Answered on Jan 15, 2016
C7000
what is the malfuction Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/14/2016 11:14:47 PM • Konica Minolta... • Answered on Jan 14, 2016
Konica C7000 stopped printing C-0213 error code came up
The paper exit pressure home sensor (PS10) does not turn ON within a specified period of time after it turns OFF. one this mite be bad: AC drive board (ACDB) • Printer control board (PRCB) • Paper exit motor (M54) • Paper exit pressure sensor (PS10) recommended you have a tech look at it believe the tech bulletins on this problem Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/27/2015 1:25:14 AM • Konica Minolta... • Answered on Dec 27, 2015
C-3102
Fusing release code drive motor for fuser or home release sensor not working . Have a tech look at this before resetting Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/30/2015 9:45:06 PM • Konica Minolta... • Answered on May 30, 2015
Konica Minolta C6500 C5500 C6501 C6000 C7000 Developer Set C/m/y/k Dv610 Logo
Popular Tags
26 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
error code 3101
  • Office Equipment & Supplies
