20 Most Recent
Coleman (5040B750) Patio Heater Questions & Answers
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
3/2/2015 10:28:08 PM •
Coleman...
Answered
on Mar 02, 2015
My coleman patio heater pilot lights but when I
Check the tip over senser,,, it is a plastic senser located under the screen, usually near the knob. It has 2 wires running to it, jumper them together and try it,, then order a new senser from the manufature.
Good Luck
5/3/2013 8:53:10 PM •
Coleman...
Answered
on May 03, 2013
Pilot light lights but goes
This can be caused by a worn
thermocouple, these are consumable itmes that can last 1 to 5 years and will need to be changed. Sometimes it can also be a faulty
tilt switch and worth shorting out the tilt switch first. Just place a wire between the leads on the small black box to short it and try lighting. Found this site very helpful
patio heater top repair tips.
11/9/2011 12:26:43 PM •
Coleman...
Answered
on Nov 09, 2011
My 2 year old (rusted and looking like a 10 year
Heaters that have rusted are tin plated or chrome finish, it can be hard to get a stainless steel heaters since some traders sell heaters as stainless steel but don't tell you the burner is made of tin. If you get a new heater just ask the question, is the burner tin or stainless steel? The problem with a burner that goes out can be a simple as changing the
thermocouple, these are consumable and last between 2 to 5 years depending on use and storage. But if you have a yellow tipping this is not good, this can be caused by wrong fuel mix or faulty gas valve and is not an easy fix. Found this site very useful
patio heater problem solving. Lots of info.
11/9/2011 12:20:31 PM •
Coleman...
Answered
on Nov 09, 2011
I have a Coleman outdoor
Use a needle. You cad disamble it and clean it and clean the old wet propane out and replace it. I have one you can have - dont need it in SO CAL - pay shipping only
7/19/2011 9:02:29 AM •
Coleman...
Answered
on Jul 19, 2011
Charmglow gas patio heater
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
7/6/2011 7:39:09 PM •
Coleman...
Answered
on Jul 06, 2011
5040-750 patio heater lights, mantles
are there other indicators that could tell you if the heater receives electricity?
If you have a power tester please test the plugs of the heater for continuity or try plugging the heater to a known good power outlet.
If you've plugged it into a known good power outlet and it still does not light it could mean that you have a wiring problem.
Hope this helps!
7/4/2011 4:38:23 PM •
Coleman...
Answered
on Jul 04, 2011
What mantles do I use for a coleman patio
You didn't list a Model Number for your Patio Heater, so it's hard to say, which one you need.
However, you can contact Coleman direct at 800-835-3278 give them the Model Number and you can order one directly from them.
Hope this helped you.
5/12/2011 9:54:10 PM •
Coleman...
Answered
on May 12, 2011
Yellow flame
the burner air ports are blocked lack of air to burn needs a service as it will start to soot up
12/6/2010 3:15:22 AM •
Coleman...
Answered
on Dec 06, 2010
The pilot light ignights but
i suggest you change thermocouple on heater it is the pilot control, firstly i would find where it attach's to valve and make sure it is screwed into valve properly (do not over tighten). If the pilot still doesn't go change the thermopile and if that don't work change the valve, but it most likely the thermocouple
11/23/2010 12:46:01 AM •
Coleman...
Answered
on Nov 23, 2010
Hi I push the button and hold it for many times
You may not be getting gas to the pilot, could be the regulator if the heater isn't new, could also be a blockage in the pilot orifice, the orifice is very, very small on these heaters.
11/14/2010 2:23:15 AM •
Coleman...
Answered
on Nov 14, 2010
Gas is being delivered, pilot
Make sure the switch on the thermostat is on heat.make the power to the heater is turned on.
if you can hear a click at the gas valve then it is stuck from sitting with out use.
10/9/2010 1:33:38 AM •
Coleman...
Answered
on Oct 09, 2010
Can not get the
on this unit you need to hold the button listen till you hear the propane then turn it till you here a clip and it should lite
8/19/2010 2:21:14 AM •
Coleman...
Answered
on Aug 19, 2010
My patio mushroom heater lights up ok but keeps
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the
thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with
attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
8/5/2010 3:47:51 AM •
Coleman...
Answered
on Aug 05, 2010
