20 Most Recent
HP Officejet Pro K550dtn InkJet Printer Questions & Answers
Replaced HP 88 Printheads, still receive same
You either got a defective printhead or you are using generic inks, HP got real smart and added chemicals to their ink, if the printer doesn't see the right chemical makeup it will give that error and you need to flush the printhead and the pump and hoses with HP ink or the error will stay.
How to reset printer hp offiject 6700
- If the user cannot solve an issue that has been troubleshooting frequently, then obviously the last thing would do is to reset the printer.
- To perform a reset, turn on the 123.hp.com/oj6700 printer by pressing the power button.
- With the printer turned ON, disconnect the power cord from the rear end of the printer.
- Remove the power cord from the wall outlet. Wait for a few seconds and re-connect the power plug back to the outlet.
- Reconnect the power cord to the printer's rear. If the printer does not turn ON automatically, press the Power button. for More visit https://goo.gl/t55XMJ Call Our Toll-Free 1 888 224 4280
Office jet pro 8710. will not print says the paper size detected 0 by the printer does not match the paper size selected (8.5x11in) for the print job
The Officejet 8710 printer can face paper mismatch issues if the paper settings are not set properly in the Print Preview box. Try setting the Paper Type option to Plain in the settings window that appears before performing the print. Change the settings to 8.5 x 11 in both the copier and the printer setting. There can also be an issue with the paper tray. Set the paper width guides correctly. Try printing a Configuration report to determine which paper size the printer is configured to. Any bits of paper stuck inside the printer roller might also cause paper feeding errors. Open the cartridge access door of your HP Officejet Pro printer. Wait for the ink cartridges to a position on the left. Look for any pieces of paper inside the cartridge area. If any bits are found, remove them. That should solve your problem. for more support Call our Toll-Free 1-866-293-9220 or visit
https://goo.gl/Pkv63e
How to Setup 123 HP OFFICEJET 3830 Printer
How to Setup 123 HP OFFICEJET 3830 PrinterUn pack the 123.hp.com/oj3830 printer from its packaging and keep the power cords ready to connect in its respective places. Now, place the cords firmly into the wall sockets so that there are no loose connections or any power issues with the devices. After connecting the cords, press the Home button on the left-hand corner of the printer.nice the basic setup is complete, install the printer software by visiting 123.hp.com or by inserting the CD which came with the printer. Follow the instructions on the screen to complete the printer installation process. Download the driver software from the website link 123.hp.com/oj3830 or 123.hp.com/setup 3830.
