20 Most Recent
Kyocera FS-1135MFP w/ Document Feeder Questions & Answers
Error c6400 in 1135
The Error is described in the Service Manual as - "Zero cross signal error The zero cross signal does not reach the control PWB for specified time."
This can be a damaged wire harness between the High Voltage PCB and another board or a defective Power Source PCB. Bad power at the outlet can also cause this.
Move the machine to another location and make sure nothing else is plugged into the same line. If the problem goes away have an electrician check your wiring.
If the problem still occurs have a Service Technician check the machine and replace the bad part.
2/27/2015 2:14:46 PM •
Kyocera...
Answered
on Feb 27, 2015
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
Kyocera Printer wont scan
Check Network Connection: Ensure both devices are on the same network.
Restart Devices: Power cycle both computer and printer.
Verify Scanner Settings: Confirm correct scanner selection.
Update Drivers: Install latest printer drivers.
Firmware Update: Consider updating printer firmware.
Inspect Cables: Check all connections.
Contact Kyocera Support: If issue persists, reach out to Kyocera's support.
