20 Most Recent
Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio Questions & Answers
Nedd to reset radios back to factory settings.
What is the signal strength of the radio and is other similar radio able to communicate?
It could be that the signal antenna of your radio is faulty, maybe that is why it is not communicating with other radios. check if others are able to communicate with each other because the fault could be from the radio weather station.
I will advice you check the manual of your radio to get the procedure on how to reset it.
Take care.
Service manual for gm338
http://www.motorola.com/governmentandenterprise/contentdir/zh_CN/Files/ProductInformation/GM338_Aus.pdf
LI 6000 2-way charging base does not charge- no indicator light
Dear sir,
It seems that ur adoptor is not ok , u can save the money by purchasing any 9 V adoptor, It available for less than 1 USD in our country ..& cut the wires of ur budled adoptor & fix them in correct polarity with the wire connecting the charger base ..( before doing this proces check voltage output from adoptor by using a multimetre.)
Regards
Raj
Cobra LI7200
Please don't touch any internal adjustments. It is like a 10 digit combination lock that is set to open. If you start changing the numbers, you will never get it open.
I think the problem is with your tone coded squelch (CTCSS). Your radio channel is like a telephone party line. If your CTCSS is not on, everytime you turn your radio on you will hear anyone on that channel that is close enough to hear.
If you are trying to use these radios for serious communications, that will drive you nuts to hear everybody else talking but not about what you need to hear. To try to mitigate this problem, CTCSS was created. There are 38 different codes. If you for example set your unit to operate on code 11 and your other unit is set to operate on code 12, you could not hear each other.
Now let's add a third unit set to not use CTCSS at all. Neither one of you will be able to hear this third unit but he can hear both of you. Now you set the second unit to code 11 like the first unit. Now you will be able to hear each other. The third unit will still be able to hear both of you but since he is not transmitting code 11, you still can't hear him.
If you are hearing some traffic, it is because they have their CTCSS set to the same code that you are set to. Look in you operators manual for CTCSS Privacy Codes. Set your radios accordingly and I think you will be in business. Let me know if this doesn't take care of you problem.
Cobra LI7200
Dear sir, Pls see if u have same privacy code , pls turn of all privacy codes & sub codes keep every code "00" & keep same channel in both the radios , try now
Regards
raj
Charger / Adapter
Radio shack sales a universal power adapter. <CAUTION> make sure the adapter is set to the correct voltage and that the tip is set to the correct polarity. The only other option is to order the adapter from Cobra.
Pat
A bad speaker
Hello beddog,
I would recommend contacting the manufacturer directly for parts. You can find their contact information through their website at:
http://www.cobraelectronics.com.
Best Regards
Ken
Go Ahead. Use Us.
