20 Most Recent
Intertherm P3RA-030K Air Conditioner Questions & Answers
S3RA-036K
Any capacitor of the same rating as old one will work, it doesn't have to be a Intertherm part. I would say its 25-35 ufd 370v.
11/26/2014 12:24:49 AM •
Intertherm...
Answered
on Nov 26, 2014
Nordyne
Check air filter, check fan belt for proper tension if applicable. Is the coil froze up? Remove blower wheel and clean it.
11/25/2014 10:32:58 PM •
Intertherm...
Answered
on Nov 25, 2014
P3ra-048k uses what type of refrigerant and manufacture charging chart
This sounds like a trick question. Are you a service man? You must know HVAC well if you know sub cooling! There is a tech info plate on the unit that tells you how much and what type of refrigerant. Check the fan direction and if indeed it is running at all. If its icing up back to the compressor is the condenser fan running? Make sure you thaw it completely before trying to recharge it. Also check for plugged filter dryer, and as a last resort see if it has a plugged or incorrectly sized orifice or TXV. Charge by superheat method.
11/25/2014 10:28:51 PM •
Intertherm...
Answered
on Nov 25, 2014
Need copy of the wiring diagram
I am sure there is one to download. If google is no help, just ask some deep web specialists, e.g. http://manualfox.com - this is a manual search agency and if they don´t find it, it does not exist in the Internet.
