20 Most Recent Maytag Atlantis MAV6260AWW Top Load Washer Questions & Answers
Washer makes grinding/loud sound and will not agitate-spins fine
Look under the washer. Is there a little pile of black rubber shavings? This sounds like the basket coupler between the motor and the drum. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum. In your case, I suspect that the holes are intact in the direction of spin, but as soon as it reverses for agitation, it breaks out through the back of the holes.
7/10/2017 3:36:52 AM • Maytag Atlantis... • Answered on Jul 10, 2017
0answers
0answers
0answers
Maytag Atlantis mav6200aww. In
It seems as though the controller is "Hanging Up?" now this doesn't seem to be supported by any "Faulty" parts, as evidenced, it WILL work, after it is re-initialized, it is also doubtful it is a sensor either, though it may pay to check them all? So this really only leaves us with the actual controller itself, which is where i think you will find your problem, the only "Fix" is complete replacement,. with a new or reconditioned one.
If you wish to DIY, please find a link below for a service manual.
http://allrepairmanuals.com/maytag-washer.htm?model_number=MAV6200AWW
According to your description very likely the problem is a bad timer/electronic control.
- The part number for the timer is AP4029054
Here are the breakdown diagrams and Replacement parts for MAYTAG MAV6200AWW ' AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/washer-repair/39232-maytag-atlantis-rinse-timer-problem.html#ixzz1PefXQdqK
see link below for original data.
Otherwise please contact a local or head office of Maytag, and ask for a referral to an authorised service center, then when in touch with them get a serviceman to call and ONLY first ask for a "Quote" as to what's wrong and how much it will cost. Then one can proceed from there when armed with the relevant info.
6/20/2011 1:29:20 AM • Maytag Atlantis... • Answered on Jun 20, 2011
Maytag A412.....will not agitate....cannot turn
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter.
5/7/2011 6:53:13 AM • Maytag Atlantis... • Answered on May 07, 2011
WASHER WILL FILL BUT THEN NOTHING BUT A BUZZING
How cold was this garage? Could you have ice in the pump? Let it thaw a few hours, (or better yet, overnight) then try again.
11/28/2010 1:48:15 AM • Maytag Atlantis... • Answered on Nov 28, 2010
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
11/18/2009 9:11:22 AM • Maytag Atlantis... • Answered on Nov 18, 2009
What is the product capacity of older Maytag
I researched the exact same question recently and found on a website somewhere that it is 3.2 cu ft.
7/22/2009 7:10:51 PM • Maytag Atlantis... • Answered on Jul 22, 2009
3answers
Need some help!
sounds like the lid open switch got stuck..check that with a chopstick or something like that, to ensure that it's not stuck. won't run if that switch is stuck in 'open ' position.
7/5/2009 6:06:51 PM • Maytag Atlantis... • Answered on Jul 05, 2009
2answers
Maytag washing machine #mav6260aw
I found the crazy sound where comes from, it was an aluminum ring in the drain pump.
First of all, I took out the belt under the bottom, checked moter to run itself, it was fine, so, I suspected some waste in somewhere, it was lucky I disassembled the drain pump first, no waste in the drain pump, but I saw a ring that was cut under the pump (seems should be connected), when I try to spin the pump wheel by hand it is broken because of the ring.
I ordered the entire drain pump on the website, the cost $74 + delivery fee, I recognized Maytag re-designed the drain pump due to the ring ( new pump does not have the ring anymore). Now the washer works fine like new.
3/11/2009 12:02:39 AM • Maytag Atlantis... • Answered on Mar 11, 2009
Maytag Atlantis MAV6260AWW Top Load Washer Logo
46 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag atlantis mav6200aww in
  • Washing Machines
