20 Most Recent
Bosch 24 in. SHE56C05UC Stainless Steel Built-in Dishwasher Questions & Answers
Bosch she56c02uc dishwasher does not cycle, stuck on wash
If the display is stuck on 2H it often means the heater is
not working. If the water is not heated, the cycle will never complete. It is
possible the heating element is bad, but a more likely problem is with the
control module PC board. The solution requires some basic repair and soldering
skills plus the tools to do the job. Bosch recommends re-soldering the
connection to the heating element relay (see page 11 of "SHU/SHI/SHV Dishwasher
Troubleshooting Tips")
free
download here
The problem is that the circuit board copper is not
heavy enough to handle the heating element current, causing the copper to heat
and melt the solder connection. A better solution is to solder a short length
of copper wire between the two pins to provide more copper and reduce the
chance of heating as shown in the attached photo.
Bosch SHX46A dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Hi ther ,
Are your dishes coming out clean? I had the same problem and it turned out to be my pump that needed fixing. I had to remove the pump and change the impeller that was broken. The part cost is about 90 dollars. The work took me about 6hrs.
It requires you to dissasseble to back and bottom of the house and pull the motor and pump out.
Streaks and film on glasses
Bosch dishwaser
need to look at operating booklet and see what F stands for.then rectify it.
Bosch dishwasher digital readout
It sound that the problem is cause the water level switch.The switch level is a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube.
In case it doesn't react, you should replace it.
Good luck !
Bosch dishwasher error code c1
HiPump-out not accomplished in normal time.Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
1/20/2024 2:53:57 AM •
Bosch...
Answered
on Jan 20, 2024
Bosch dishwasher leaking on the back
AI Bot Answer Deleted.
In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
8/27/2023 3:43:43 PM •
Bosch...
Answered
on Aug 27, 2023
