20 Most Recent Bosch 24 in. SHV57C03UC Built-in Dishwasher Questions & Answers
The latch won't engage
Check repairclinic.com for videos, parts, diagrams or appliancepartspros.com or YouTube.com
11/21/2017 4:29:31 AM • Bosch 24 in.... • Answered on Nov 21, 2017
Bosch dishwasher runs for 4 1/2 hours
Hello, grs I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>> http://home.howstuffworks.com/dishwasher.htm Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike http://beta.fixya.com/users/mc1bean
10/27/2011 10:42:11 PM • Bosch 24 in.... • Answered on Oct 27, 2011
I have the above dishwasher
Hi
You are right it is the control board that is going bad and should be replaced....replacement instructions usually comes when you buy the part however, you can also check this video:
Hope this helps...please post back for further assistance.
Daniel
2/28/2011 8:14:49 PM • Bosch 24 in.... • Answered on Feb 28, 2011
I have bosch shv57c03uc/40 built in and the water
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
6/4/2010 8:44:24 PM • Bosch 24 in.... • Answered on Jun 04, 2010
Dishwasher was damaged
Yes, you can fix it. Go to www.repairclinic.com and look up the model number of your d/w, select the parts that are damaged and you have a new d/w.
Have fun.
1/23/2008 10:30:55 AM • Bosch 24 in.... • Answered on Jan 23, 2008
2answers
Bosch dishwasher start with CL code
That is just saying the Child Lock (CL) has been activated.
Deactivate the child lock ' Bosch
Bosch Home https://www.bosch-home.com > ... > Get support 1. Press and hold the start button for three to five seconds ... When the child lock is activated, there will be a message "CL" in the display and all the washing ...
Bosch dishwasher child lock problem
Bosch-home.co.uk https://www.bosch-home.co.uk > ... > Dishwashers Hold down the lock button for three to five seconds. You should hear an audible beep and/or see the symbol disappear. The child lock is now deactivated.
What does CL mean on a dishwasher? And how do I fix it?
Quora https://www.quora.com > What-does-CL-mean-on-a-dish... This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ... 9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
How to turn off the CL on the display of a bosch dishwashe...
JustAnswer https://www.justanswer.com > Appliance Repair Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone. 1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your ..https://www.youtube.com/watch?v=Xr4DBwACUW4
4/15/2024 10:37:04 PM • Bosch... • Answered 2 days ago
Water dripping out of last hole in Bosch upper spray arm getting dishes below wet
the unit could be un-level
3/22/2024 4:43:03 PM • Bosch... • Answered on Mar 22, 2024
Model shy56ao5uc/23. How can I turn off alarm?
YOU CAN ONLY LEARN TO ATTEND TO IT WHEN IT SOUNDS . THEY HAVE NO FEATURE TO TURN IT OFF OTHERWISE
3/4/2024 11:14:58 AM • Bosch... • Answered on Mar 04, 2024
2answers
Bosch dishwasher error code c1
HiPump-out not accomplished in normal time.Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
1/20/2024 2:53:57 AM • Bosch... • Answered on Jan 20, 2024
I have a Bosch SHE58C. What is making this noise?
This is the parts schematic that shows all the parts and where they are located. The noise is either something stuck in the pump or a dry bearing. https://www.searspartsdirect.com/model/25b4iqte9a-001794/bosch-she58c02uc-50-dishwasher-parts ..
1/18/2024 1:01:01 AM • Bosch... • Answered on Jan 18, 2024
3answers
Will a new Bosch dishwasher fit into the space of my 20-yr-old Bosch dishwasher?
Dishwashers come in standard sizes. Your old one is 60 CM wide and made for built in. https://www.bosch-home.ca/en/supportdetail/product/SGU4025AU/31 DISHWASHER 60 CM BUILT-IN/BUILT-UNDERSGU4025AU/31 As long as the new one is also for built in, the dishwasher will fit. Measure the height of the space you have. There may be a little height adjustment on the feet. ..
1/3/2024 11:11:40 AM • Bosch... • Answered on Jan 03, 2024
Bosch dishwasher leaking on the back
AI Bot Answer Deleted. In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling. An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
E15 Bosch Dishwasher Error Code
8/27/2023 3:43:43 PM • Bosch... • Answered on Aug 27, 2023
Bosch dishwashers E 24 erro code.
8/15/2023 10:21:48 AM • Bosch... • Answered on Aug 15, 2023
My Bosch SMS6HCI01A makes a sound on closing door
8/15/2023 10:14:52 AM • Bosch... • Answered on Aug 15, 2023
Bosch SHU66C05UC/40 is not cleaning dishes and leaves film
It needs descaling. Try CLR in a wash
7/25/2023 4:52:38 AM • Bosch... • Answered on Jul 25, 2023
Bosch SHU66C05UC/40 is leaving white film on the dishes.
Add some salt.
7/24/2023 7:52:04 PM • Bosch... • Answered on Jul 24, 2023
I am not getting water into the dishwasher after changing the inlet valve
Check if there is anything in the large item trap or blocking the water level sensor. The dishwasher won't try to fill if it believes it is full. Try pressing and holding the Start button for 3+ seconds. The Clean LED should light up in a minute. If it does, try the on/off button and starting a new cycle. (This just clears any old programs from the memory.) Some washers will stop if they detected a water leak. Sometimes turning off the power for a while and checking for water in the cabinet below the dishwasher or in the motor area is useful. The more likely items to check: Check the wiring between the inlet valve and the control board. Check the wires for corrosion at the connecting pins and for continuity. Broken conductors don't send a signal to open and close the valve. If those are okay, then the control board itself may be faulty. Since this dishwasher is discontinued by the manufacturer, I don't know if all of the parts are still available. The only parts list for the SHE3ARL2UC/28 that I found is here: https://www.partselect.com/Models/SHE3ARL2UC/ . They don't list any wires or the control board. I hope this helps. Cindy Wells
7/9/2023 9:13:29 PM • Bosch... • Answered on Jul 09, 2023
Bosch dishwasher wont start
The water supply is inadequate for your dishwasher.
4/29/2023 6:31:03 AM • Bosch... • Answered on Apr 29, 2023
Bosch 24 in. SHV57C03UC Built-in Dishwasher Logo
13 questions posted
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
bosch shv57c03uc 40 built in water
  • Dishwashers
