20 Most Recent Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Questions & Answers
2answers
Maytag Neptune MAH8700AWW Error Code Hr
When starting the spining cycle I could observed that the pump's cable touch the metal floor. When that happen the "Hr" error code appear inmediately. Conclusion: With years of use the cable's insulation was wear out. I strap the cable so it can not touch the metal and problem solved. Hint: You should also check the dampers (4) for excesive wear.M.Caro
3/20/2023 11:58:55 PM • Maytag MAH6500... • Answered on Mar 20, 2023
Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
6/14/2022 6:56:37 AM • Maytag MAH6500... • Answered on Jun 14, 2022
4answers
Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
5/14/2021 1:07:43 AM • Maytag MAH6500... • Answered on May 14, 2021
3answers
Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
9/11/2020 7:22:33 PM • Maytag MAH6500... • Answered on Sep 11, 2020
0answers
Mah2400aww
Be the first to answer 1/18/2018 5:38:36 PM • Maytag MAH6500... • Posted on Jan 18, 2018Be the first to answer
CANDY CM1612 WASHING MACHINE
dose the drum spin at all please clarify eric
1/4/2018 9:32:45 PM • Maytag MAH6500... • Answered on Jan 04, 2018
I have the MAH8700AWW model and the smell is awful!
I have read that the imbalance/drum problem is a known problem and should be covered under warranty. also, that the smell is also a known problem and can only be fixed by replacing the outer gasket. Which seems like a waste of time, as how long would it take for the new gasket to smell?
6/3/2017 10:50:41 PM • Maytag MAH6500... • Answered on Jun 03, 2017
2answers
Door won't open on my front loading maytag washer
Try unplugging machine and then plugging back in see if that resets it. Also if you still cant get it unlocked there is a emergency latch release. Remove the 4 phillips head screws holding dispenser trim/lid. Now look in in front of (closest to door) now look for what appears to be a weed eater line (it should be green) pull gently and it should release door. Hope this helps get to your sons socks.
9/30/2015 6:35:12 AM • Maytag MAH6500... • Answered on Sep 30, 2015
2answers
Cleans good but when it spins it sounds like q jet taking off?
May have a piece of cloth, plastic etc that may be stuck on something between the belt and the drive system, have a look underneath/back to see if anything is there.
4/2/2015 6:25:28 PM • Maytag MAH6500... • Answered on Apr 02, 2015
Error code od maytag Neptune
http://homeguides.sfgate.com/maytag-neptune-washer-model-mah8700-troubleshooting-codes-102595.html. Here's the site for Maytag Neptune Washers. You can also find other modes there. Hope this helps. Enjoy.
2/16/2015 10:17:58 PM • Maytag MAH6500... • Answered on Feb 16, 2015
How do I replace the door seal on an HE Maytag washer
Watch this and you will have it done in no time If you need further help, reach me via phone at https://www.6ya.com/expert/timothy_c6f309c0f75b6f43
7/21/2014 3:50:24 PM • Maytag MAH6500... • Answered on Jul 21, 2014
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
185 questions posted
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
maytag front loading washing machine
  • Washing Machines
