20 Most Recent Maytag Neptune Washer Questions & Answers
2answers
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
10/14/2020 11:28:10 AM • Maytag Neptune... • Answered on Oct 14, 2020
NEPTUNE WASHER BEEPS,,WANT TURN OFF OR START
When door locks like that next time. If you remove the top of the machine. Reach down inside on left side. There is a small wire cable that you pull up on. Will manually unlock the door. Then plug power cord in to wall. Power it on let it go through reset cycle and it will work properly again. However if you can't reach the latch through the top. Tilt washer forward and reach up from the bottom. If you get an F1 code it's low water pressure.
12/31/2019 10:49:27 PM • Maytag Neptune... • Answered on Dec 31, 2019
2answers
Washer started and then stops mid cycle
Try unplugging it for a minute and plug back in, that should reset it.
9/24/2018 6:27:23 PM • Maytag Neptune... • Answered on Sep 24, 2018
What does f1 E7 errors mean on neptune washer
There may be a problem with the Appliance Control Board, or the associated wiring. Power unit down by turning off the circuit breaker(s) for one (1) minute. Power unit up by turning on the circuit breaker(s). Monitor the oven for one (1) minute to ensure the error code does not display again.
4/25/2018 3:19:33 PM • Maytag Neptune... • Answered on Apr 25, 2018
Mhw2000 rinse and spin cycle not working
It won't spin if it cannot pump out ALL of the water. Check the outlet pump for obstructions and clear. Check pump to see if its pumping.
6/23/2017 10:08:33 AM • Maytag Neptune... • Answered on Jun 23, 2017
My washing machine door will not unlock. I have a
some doors will release if given a hard bang where the interlock is...at the door catch......... cheers
5/28/2017 4:48:40 PM • Maytag Neptune... • Answered on May 28, 2017
2answers
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
6/29/2015 3:15:21 AM • Maytag Neptune... • Answered on Jun 29, 2015
0answers
I have a 14 year old Neptune that run great except now no hot water.
There's a fill valve combination on most washers. On the simpler, cheaper models they're simple to change. It's where the hoses connect, it's usually plastic, and there is a hot and a cold valve in the assembly. Hot opens for hot water, cold opens for cold water, and both open for warm water. apparently the solenoid valve on the hot water side has failed and the unit needs to be replaced.
5/23/2014 7:04:34 AM • Maytag Neptune... • Answered on May 23, 2014
Whybdoes water remain in machine at end of wash?
If the drain pump malfunctions...or is clogged then it will not empty within the time cycle and the unit will time out. the pump in at the bottom of the machine
5/23/2014 7:00:32 AM • Maytag Neptune... • Answered on May 23, 2014
0answers
Water flows out door while in use
Check the door gasket/seal for damage. Check to see if the door's mounting brackets are loose by lightly moving the door up/down. Also check the level of the machine to ensure that the frame is not twisted.
4/22/2014 3:18:54 AM • Maytag Neptune... • Answered on Apr 22, 2014
Washing Machines Logo
468 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
14 year old neptune run great except now
  • Washing Machines
